It is official. T1 Torsen diff's are weak.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Took the chance running a JDM Torsen diff for a few months, since they give much better traction than a clutch type LSD, but it is now toast. It went out in a strange way too. It developed a lot of slack over the course of a day, causing lots of driveline bouncing and surging. I had the car up on jackstands checking for loose tranny mounts or a broken subframe. With the engine revved and one quick pop of the clutch with the wheels in the air broke it, confirming my suspision.
With daily RWHP around 350-370, this is pretty weak. Never did any burnouts.
Before I bolt my stock LSD back in, should I beef up the clutch packs? I'm sick of swapping this shit in and out!
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
you put the correct fluid in there right?
lol...i dont know crap about diff life but one dying that fast seems lame...and since it was new i could see the slim possiblity of not filling it with lube on accident.....maybe
Running one with 450+ for many 1000's of hard miles with the only failure being a toasted pinion bearing during a high speed run (had a cluth LSD fail in the exact same way)
The T1 Torsen WON'T take high shock loads so maybe that's the difference!
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Are you running a JDM T1?
drjonez
the motor city
www.4cefed.com
http://www.mkiiitech.com/forums/viewtopic.php?t=543
