If your looking to put 2JZ cams into your 1JZ, look at this
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
No.
It's the mass of air going into the motor, boost is just a factor in this.
Saying it's the size of the turbo is actually quite right because as a rule of thumb bigger turbo's move a bigger mass of air.
Kosh
144
Edmonton
The thing about this topic is that there are so many factors involved that you can't really say its any one thing, and every little thing affects it to some extent. I'd say the biggest factor to float would be the spring rates and the duration. Maybe boost level and flow if they're large enough to have an effect. just my .02
porsches4lunch
101
Miami
Bigzavs said:
well, im about to be getting a set to work on from a guy on here, and ill take some before and after pics with a digital mic, just to let you guys see
They are on their way, Thanks AGAIN, and i am looking forward to it. :icon_lol: ::w00t::
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
sounds good man, like i said ill be ready for em.
Andrew, how long did it take for you to get em back? i cant remember
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
Hey guys sorry to come in late, haven't been near the computer for over a week, was in rome all week ;)
Anyways, the diff in cams are as follows.
100+90-100 for maching 2jz cams gives about 15-20 hp over previous peak and peak power drops off near 6500ish so
$200-250 for 2jz usdm cams
Crower's (GB) normal price form me 535 gives 40-60 HP gain over your previous peak however, on the 272 small core aka 264's you will hold power till about 700 and then only bleed 30-50 by redline of 8k vs the stock which bled 130 whp by 7800 rpm, and the 2jz which will bleed about 70-100 by 8k
HKS's 264's have more duration but less lift which equates to little laggier spool up but should hold power to redline and possibly make a little more nearer the 7000 mark.
Stock springs are good for FAR more then 7000 RPM more like 8500-9000. I reved to 7800 EVERY day and usually bumped 8300 in first gear because it was over so quick.
I ran the crower 264 with both upgraded springs and stock springs with no problems.
So in short, pay half the price for real cams and get roughly half the performance gain.. IMO if you upgrade your turbo you need to upgrade the revlimit on the 1jz, it LOVES revs and has fuq all with out boost.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
true, but i think this is a lil more for guys on stock twins than for 1J's with a single setup. just too eek out that lil bit more up high.
porsches4lunch
101
Miami
well, i am actually putting them on a 1JZ with a T76 single and a stinger stand alone so we will see how well they actually work.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
Mods: is it possible to get this stickied or if i start another thread with the prices to get that stickied so that people dont make more posts about the 2J cams?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Hopefully soon. I replaced my alternator and it didn't fix my charging problem. I've been really busy to mess with the supra. So, next couple of weeks before it gets cold out.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
i had a charging problem on mine, and it turned out to be the power wire of my alternator had somehow come halfway undone from the two wires near the fusebox
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
porshes4lunch, got the cams today and thanks to fedex taking forever and a day to deliver them, i made it to the machine shop with literally 1 frickin minute to spare, but they should be done very soon
porsches4lunch
101
Miami
Thanks dude. I FREAKIN HATE FEDEX AS WELL!!!!!! They "LOST" a shipment i sent as well.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
cams will be out to you today man heres two pics i snapped before boxing them back up
1JZ cam right, 2JZ cam left
2JZ top, 1JZ bottom
porsches4lunch
101
Miami
2JZ top, 1JZ bottom
You Da man :icon_bigg I just got the Stinger from Arron as well so now i just have to start puttin it ALL together.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Good stuff Ben. I really need to put mine in. I've been real busy lately and haven't had time. Well, except for the burnout vid.
