HKS Filters suck
staticpat
Supra Chair!
Birmingham, AL
... ERRR I mean get sucked
I had some major WOT problems a few months back, and just found this picture on my camera. The engine kept choking out and dieing over 2800RPMS. I logged with my wideband, spent an hour or so checking hoses and boost leak testing. Then my roomate pointed out something.
Hmm that may have been the problem. The turbo sucked up and chewed my HKS mushroom filter to pieces. It was clogging the AFM hardcore. The funny thing was I took off all the intake piping and AFM to boost leak test and didn't notice green foam pieces everywhere.
staticpat
Supra Chair!
Birmingham, AL
Many pieces were found in the turbine blades. I'm running a LEX so theres a space for chunks to fit. Some made it through the honeycomb too.
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
So basically we have two options... coat the insides of our afm with a nice layer of oil... (if oiled in correctly).. or worry about foam getting sucked into the afm (if mistreated)... hmm
I'd think it's much easier to have a foam filter, when you check your oil (I do it every morning) just look at the filter.
89turbotoy
2 89 supras 2jzgte/single
Jul 30, 2006
309
cincinnati
or just oil your filter correctly and dont worry about it. IMHO
the HKS is an OIL SOAKED FOAM filter
it is NOT cleanable, you replace it
failure to replace causes issues like this
it's worse thna a K&N as not only does oil get in, but it doesn't filter that good, and it does break down.
Apex'i AEM, ect are better as they're dry and aren't foam...
FYI: the BEST filter you can run on your car is..... S T O C K
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
hks dirt sucker - crappyest filter ever and same with greddy's new one too
k&n - oily mess that will wrerck your afm sencer over time
blitz stainless wounder does not clean much but will last for ever
apexi aem best out there .
