Pistons are CP, i dont think they do assymetrical ones. i think thats just JE?
valve pockets are the same size on both sets... the problem was a bit more dire than that, and i wouldnt have minded a bit more valve clearance anyway. those pistons wouldnt have worked at all in this engine, and probably not on a less modified one either.
problem was the
placement of the pockets... they were spaced at 34mm when 7m valve spacing is at 36mm. because all my valve shit is so close to everything, this was no good. CP were great about it all and remade me a new set with no fuss. valve spacing is now spot on at 36mm
so i got ready to (once again) mock up for piston to valve clearance, and i took a couple of pics this time
prepare the head with 1 cyl worth of valves and set lash somewhere in the ballpark of right
install piston and rod into #1. got sick of shitty piston ring compressors so made my own for this engine. the tapered lead works really well, you center it over the bore and just drop the piston in! 1 tiny tap by hand it and falls all the way home. i LOVE this thing! makes life so much easier!
install used 1.2mm MHG and setup timing. i left the cam gears loose to begin with to give some more breathing room in case things wanted to lock up
whirl it around a few times, nothing hits, lock up the cam gears, still all good, it doesnt stop and i dont feel any resistance apart from the valve springs.
take it all apart, thinking all might be good and i can finally put the bloody thing together.
SO. FUCKING. CLOSE.
valve just kisesd the ceramic coating and took a bit off (not thrilled about this) but never actually hit the aluminium of the piston.
havent decided which way to go from here. i guess my options are:
get a 2mm HG and drop down to more like 13:1CR, pretty sure this will give heaps of clearance
make a fixture for the CNC and cut the valve reliefs a bit wider, then probably have to recoat piston crowns
machine the OD of the valves down a bit and add a mad chamfer
start from scratch on a new head and mill less off it (hell of a lot of work)
any other ideas??? intake valves already have to get cut a bit deeper into the head but it wont be enough to give sufficient clearance once everything is at temperature.
so frustrating!
