HELP!! Windows wont roll up!!
rot 90na-t
slowest project ever
Apr 13, 2006
259
Westminster, CO
Hey guys i need a little help..
So my windows worked friday, i park the car for a day, start it up yesterday, roll my driver window down and drive home. Low and behold, when i got home my driver window wouldnt roll up and the passenger window wont roll down...... ANY ideas???? couldnt find the fuse for the windows, is it doubled with another accessory?? anything helps thanks
rot 90na-t
Apr 13, 2006
259
Westminster, CO
thank you sir, my guage cluster isnt working either so ill check that out! speedo, tems, and a few warning lights work but no oil, volt, water temp or rpm..
A-to-the-J
Panda™ and Pre-89 Gracer™
Feb 19, 2006
1,081
Anaheim/West Covina, CA
rot 90na-t;1003626 said:
ok so the seat works, but still no windows.
swapped the guage fuse out and still no rpm, water temp, oil psi, or volts....::dunce::
did the gauge fuse blow after you replaced the fuse?
when the gauge fuse blows, the windows, power locks, gauges and climate contol don't work. surprisingly, there are tons of things related to the gauge fuse.
i had to track down all the wires that were crimp connected and re-solder them, then shrink wrap them. I had some help from Jose and Ernie though. It kept blowing the gauge fuse til i found the last one.
rot 90na-t
Apr 13, 2006
259
Westminster, CO
dont know if it did, how do you check that 30A fuse? it appears to be sealed, i cant see inside of it...
found the last one what? i have climate control disconnected at the moment, but i believe my power locks still work...
could this plug have anything to do with my guage problem?? i recently swapped in an engine from a 92, my car is a 90. everything works fine and hooked up with ease as it should, but the bottom connector was on the 92 harness with a matching plug under the glove box of the 92, the top one was from my 90 which has the other end under my 90 glove box..
after the swap, this was the only difference in the two cars, and now my guages dont work. the windows worked up until yesterday though....
A-to-the-J
Feb 19, 2006
1,081
I was talking about the 7.5A fuse in the driver's side kick panel.
the last wire that was crimp connected, and re-soldered it.
use a fuse tester to check the fuses. check the wires and the grounds as well.
rot 90na-t
Apr 13, 2006
259
Westminster, CO
Orion ZyGarian;1003661 said:
Not necessarily related, but check your window switch contacts. I didnt even have contact cleaner or a good Brillo pad but I was able to clean them enough to get them working perfect again
so literally take the switch off of the main box and clean that connector correct???
mk3supra91
34
Jersey
Yes, clean the connectors and the part where the metal switchs touch the metal base, my passanger window did the same thing, it would go down but not back up. After I cleaned it out if works like new.
MadNad
46
Lafayatee, CA
Careful on the driver side. My window lock spring popped out before I even had a chance to see how it went back in. Luckilly I never need to lock my windows :).
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Ive had to clean the contacts of several window switches and have always been able to make them work. I would say you have several electrical issues though. God I hate wiring problems...I just cant wrap my brain around them.
rot 90na-t
Apr 13, 2006
259
Westminster, CO
Ya i dont know what the deal is here... I cleaned the switches and contacts.. my window lock spring popped out before i knew how it worked too.. still no windows.. my seats and locks work, checked fuses and swapped out the relay.. nothin. man how frustrating.
