Are all the heater control valves between 86 and 92 the same? I went to local autoparts stores but none carried so I may have to go check out a junk yard. All help is appreciated
xXSupramanXx;1429783 said:Are all the heater control valves between 86 and 92 the same? I went to local autoparts stores but none carried so I may have to go check out a junk yard. All help is appreciated
jetjock;1430199 said:It'd help if you were more specific but assuming you're in need of the coolant valve itself:
http://www.autopartsnerd.com/item.wws?sku=74637&mfr=FOUR+SEASONS
Swap the actuating lever from the old valve. The new valve has mounting holes on both sides so it'll orient correctly to the stock bracket. Install and be happy...
x87SUPRA87x;1429849 said:Come on chris you couldn't have asked one of us locally?? lol
Try this....
That bypasses the VSV so it should stay open, If you get heat after you change those lines your VSV is dead.
Theres one on Ebay for $89 right now too.
mkIIIman089;1430217 said:He lives!
x87SUPRA87x;1429849 said:Theres one on Ebay for $89 right now too.
