Furious But Lazy 7M owner who gave Up.
Turbo Habanero
4,229
Tucson,AZ
Had to clean up the filter but as expected didn't make much of a difference
Turbo Habanero
4,229
Tucson,AZ
gurley0916;1916042 said:
Needs some warm degreaser to clean it. That stuff is nasty
yea I cleaned it up real well. My clutch fan just kicks up so much dirt.
Im kinda worried about why the car started running different. Sucks ill jack up the car and take off the waste gate tomorrow also go over all the exhaust bolts
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Jordan you need to do a proper break in on the motor. Your doing no good with the rich A/F and antilagging. Lets have this motor last youve put alot into it.
Albert
May 13, 2009
1,710
Tempe, AZ
Jordan is your antilag on a switch like the clutch pedal? If not and you made those adjustments it might be why the car is laggier now with the timing and cuts you made...
Turbo Habanero
4,229
Tucson,AZ
Its not its setup by mph. If im going under 1mph. But it seems to work as long as I have the clutch in and going under 10mph.
But will do it at a stand still even if the clutch is not engaged
I'm going to take all the settings off that I made and see if that makes a difference
