Furious But Lazy 7M owner who gave Up.
Turbo Habanero
4,229
Tucson,AZ
suprakidd;1877865 said:
AN fittings arnt all that complicated, its pretty much standard equipment. youll catch on to it :)
yeah. I'm sure i will figure it out.
So as of right now i'm taking opinions on which route to take first, Eventually i will be buying all this stuff anyhow.
Option 1.
BC 264 cams
BC spring and retainer kit
BC Cam Gears
AEM water meth kit
Option 2.
AEM V2 standalone with all sensors and parts needed.
http://secure.xpressorder.com/driftmotion/webstore/static/i-aemversion2ecupnpforsupra1jz-gte.php
Turbo Habanero
4,229
Tucson,AZ
Albert;1878059 said:
Tony loves aem at ums
Good to know
stevenr816;1878061 said:
Didn't you buy a 128?
No sir i have yet to be bit by the pro efi bug like the rest of Arizona
So i take both of your votes are EMS ?
If i pick up the EMS ill have enough cash for 2JZGTE cams someone offered me some for $225 and there already machined for a 1J. You know just until i can out some Cams in it or i can just stay stock cams and buy AEM water/meth kit
Albert
May 13, 2009
1,710
Tempe, AZ
Well my car goofily will be tuned next week. Ill make catch the proefi bug.
There is 6 of us Mkiii owners on proefi here in AZ that I know of.
Turbo Habanero
4,229
Tucson,AZ
Ordered my CP's from DM also went to the machine shop today
Turbo Habanero
4,229
Tucson,AZ
So what do most do for a Oil cooler on a 1JZ? Also with the stock 7M cooler and Lines on the car can i just remove it all or should it be mated to work with the 1J?
This is what im talking about http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=LU&P=15
Also i was thinking i might need to replace the Oil cooler on the side of the motor what the filter connects too because of how dirty the motor was before i'm sure that this part is pretty bad inside also.
Turbo Habanero
4,229
Tucson,AZ
Clint;1878491 said:
1J's never had oil coolers, but if you wanted to you can use a stock oil cooler if you are worried about it. I've never run one...
Thanks Clint so i can just take all the lines and cooler out then and be fine i might add my own still if i have the cash left over
