flywheel bolts broken
QuebecmkIII
50
quebec
ok, I explain my story, after some donuts with the Supra, I was unable to shift any gears when the car is running, just when is close. And a grisha sound was audible when I press the clutch...
So I uninstall the R154 and at my surprise,(I anticipated a broken clutch) but 2 flywheel bolt have been broken. I found the head of 1 bolt during the uninstallation. So I supose that it was that motherfucker head bolt who block the clutch to touch the flywheel and it's why the gear won't engage.
My 2 question are
-What can cause that, I don't want that problem again
-I know nothing with the clutch but I want to know if the clutch and the pressure plate are in good condition?(It's an Aisin)
And my future goal was maybe 350-380 whp, there will resist?
For sure I will command ARP bault for the flywheel!
thank
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
QuebecmkIII;1343116 said:
My 2 question are
thank
1. Insufficient or excessive preload (torque) on the bolt can lead to it breaking. When re-installing, follow the TSRM specifications for tightening (torque value, oiling of the bolts, tightening sequence) EDIT - low grade bolts can cause this too (no photobucket access here at work)
2. Inspect the clutch components as per the tsrm (http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=CL&P=12).
Chances are the power range you are after will be a bit too much for the clutch on hard launches (I was at around the same power level and a hard 1st gear launch would cause the clutch to slip)
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Wow, it looks like someone went to the hardware store and picked up some screws that threaded into the holes in the crank... Definitely invest in some REAL flywheel screws from Toyota
Do you have the stock front crankshaft damper or do you have an underdrive pulley? You need the damper to eliminate torsional harmonic vibration in the crankshaft. Flywheel bolts can break due to torsional vibration.
BernieK
My 2 question are
thank
QuebecmkIII
50
quebec
BernieK
I don't think I have the original crankshaft pulley, it seem to be in aluminium but I don't see the brand.
That might be a good reason...
thank
i would re-surface the fly wheel, replace the clutch disc(looks chewed up), check to see if you can resurface the pressure plate, and get some arp fly wheel bolts.
QuebecmkIII
50
quebec
Thank you guys!:drink1:
I will command ARP bolts and resurface the flywheel and buy new clutch kit just to be on the safe side.
Probably a feramic clutch 6 pucks would be the best for me and I hoped to have any problems...
sylquebec
167
Quebec
Question he forget to ask : Does the flywheel bolt are thread in the flywheel itself or only in the crank? Because it will be hard to remove the broken one if they are thread in the flyweel...
QuebecmkIII
50
quebec
The bolt are not screwed in the flywheel..
gaboonviper85
3,236
Northeast Philly
hey frenchy...get a stock or ati crank pulley on your car asap...if you don't you'll be back here very soon asking how to rebuild a motor fucked by rod knock!!!
Arp flywheel bolts are a good investment but make sure to read the arp instructions!!!
supraduper
126
merrimack nh
yes, the bolts are obviously not stock.... but isnt anyone going to mention how nashy overheated that flywheel and pressure plate is..... ive never seen the ammount of blueing of the pressure plate, that is evident on his...
all that heat with subpar bolts....
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
are you talking about the blueing on the pressure plate springs? Because that is from the heat treatment of the springs, not the use of the pressure plate. The pressure plate and flywheel friction surfaces don't look all that bad.
ForcedTorque
Join the 92 Owners Group
6,099
Please take all hardware store parts off of the car before you ever try to get to 380HP or more. Maybe you should post some motor pics for a little more advise.
Driftmotion sells ARP Flywheel bolts for $25 dollars (USD)
Don't waste any time on the damper, even if you have to source a Good used one. You don't want it to have ANY pieces broken off. Torque specs for the bolt holding it on is 195 Ft-Lb.
gofastgeorge
944
Texas
Dang, where did you come up with those cheesy plated bolts?
Get the APR bolts.
And I would toss that flywheel in the scrap pile.
Notice all the heat cracks in the surface ?
I had one like that once, and the cracks went so deep, that even after it was re-finished, they were still visable.
A flywheel like that can explode (and take your feet off in the process).
I have seen it happen.
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
GrimJack;1346172 said:
Those bolts are definitely not stock. I suspect they just weren't strong enough.
At the very least, get new bolts from Toyota. Better yet, get new ones from ARP.
make sure you check the threads and follow tourge specs and use some lock tight
this is what happens if all those bolts break: :3d_frown:
