Anyone with A-1 camber arms?
Wiisass
Poodles;985783 said:
Arguably A-1 probably copied these...
Better pics from somone else's thread http://www.supramania.com/forums/showpost.php?p=967252&postcount=11
A1 did not copy anything. One of my good friends actually designed those arms a few years back for another friend's supra. He just designed them to work the way they needed to. There's only so many ways you can make a suspension arm. Tube with right and left hand threads, rod end/bushing on one side, bracket on the other and done. It's simple.
shaeff;986039 said:
You don't notice any unusual wear from using an open Heim joint? I assume you DD your car...
My concern is that grit will get in the joint, causing premature failure. :(
Chris, heim joints are something that should get checked over and replaced when they're out of spec. If you use good rod ends, you should be able to have them stay good for a decent amount of time. The only downside is they will transmit a little more noise and vibrations into the chassis. But they will control the alignment better and allow the wheel to move the way it should. Plus you get the adjustability that you would need to get the alignment dialed in exactly how you want it.
I'm still planning on doing arms at some point. Other things have just been too busy, I haven't even touched the supra since I pulled the motor and sold it. And there's still a lot that needs to be done, but I'm probably going to pull subframes soon and do something similar to what you did and probably figure out the arms at that point. I wish I had more time to work on it now, but there's just not enough room here to be doing cages and everything else at the same time.
Tim
shaeff
Kurt is FTMFW x2!!!!
11
Around
Tim- Good info. I don't mind noise/vibration. The more I can feel the car, the better. ;) I'm quite anal about checking things over on the car before I drive it/after it's driven. With the amount of street time it'll see, I doubt using a Heim joint will be a problem.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I may have to buy some of these shortly too.
Went into the alignment shop yesterday. $90 later and now I know that most of my alignment spots are frozen solid. :( I guess mine hasn't been touched since it was assembled in the factory 20 years ago.
Needless to say, my alignment is still out.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Found that out pretty quickly after attempting to tear down my subframes. All the penetrating oil/heat/impact i had couldn't loosen any of my cam bolts - the only solution was cutting them off (followed by new bushings).
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
I hope I don't have to go to that level... :(
shaeff
11
Around
Thanks for all the information, but I've got a new plan. :)
