935Motorsports supplied Injector ID
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
so i just bought a set of used Denso 550cc Injectors from 935 Motorsports on eBay.
http://cgi.ebay.com/ebaymotors/ws/e...7053&viewitem=&sspagename=STRK%3AMEWNX:IT
It says they are high impedence injectors, ok.
They came in.
So today i'm looking for clips for it online and i get some more info about denzo injectors.
I came across this:
ND made some low impedance 550s which are direct fit for the MKIII's fuel rail. Their part number is: 195500-1370. BE CAREFUL! for some reason ND used this same part number for their high impedance 450cc injector too. How do you distingush between the two? Look at the notch on the top of the injector connector-if it is in the center its low impedance, if its offset to the side, its high impedance. -grimreaper
http://www.supramania.com/forums/showthread.php?t=88151&highlight=denso+injectors
So i check out mine
was gonna get them cleaned and rebuilt.
Perhaps a mistake was made and i recieved smaller 450cc injectors? . ;)
supra90mkiii
227
Racine, WI
I would contact him. I have never had problems with him, and he may have not known.
Why start a thread saying that he cheated you when you haven't contacted him?
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
true..
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
somehow i dont think it was a mistake.
i dunno, i'm just a little angry about this.
but you're right. i'm gonna email him right now.
Can anyone confirm this? Or how a better source of info?
Jeff Lange
Administrator
4,919
4
Sunnyvale, CA
jefflange.ca
Measure the impedance of the injectors and have them flow tested. This is the best way of knowing what you have.
Also, contact him, and see if he had them flow tested or what his source is for knowing these are 550cc injectors.
For all you know, someone pulled a fast one on HIM.
Jeff
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
935 is slow and has terrible communication and customer service, but i dont think they would intentionally rip you off, i would look into it more before getting too angry
figgie
Twin Cities, Minnesot-ah
Jeff
This x1000
right now you are guessing they are not right. You need to verify that they are or not.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
Measured the resistances and confirmed high impedence injectors.
Reading is 13-14 ohms on the injectors.
He did say they were high impedence, and also gave the resistor pack plug as you can see in the picture.
Get them flow tested to determine flow rate? No thanks, I'm not paying that much money to determine i got a wrong part.
I'm waiting on an email reply.
figgie
ok folks. ONLY warning. This is theKnifeArtist thread. No need to insult, lambast on his experience, after all it is his experience (mastergrader, looking at you specifically).
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
Yeah I definitely agree with this post. If you don't call them it is likely they will not respond, I have tons of emails to him regarding my brake order (rotors/lines/pads) without a single response (ordered in June, finally have the rotors, lines and rear pads-about a week ago) but somehow the front porterfields didn't come, hopefully I get them by this Friday when I move out of my college house). If i didn't call I didn't get an answer. Rob seems like a nice guy but customer service is not 935's forte.
rodel
SoCal
May 19, 2005
2,266
SoCal
Those look like 1988 RX-7 Turbo II, 195500-1370, 550 high impedance injectors
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Yeah they are the Red High Imp 550s cause i have the Tan Low Imp 550 Injectors form the 87-88 Turbo II rx7....:icon_bigg
