'87 Drag Car 7M awesomeness
Albert
May 13, 2009
1,710
Tempe, AZ
lol I can provide the same service for a million dollars per valve cover!
It came out just as I hoped, Like Sex
Sir_2jza70
Sock puppet master
May 10, 2005
53
Canberra, Australia
fixitman04;1737497 said:
i love it... and as for the aluminum exhaust....what is the head made of?.... think people.... its not gonna melt... if it was the mounting flange tor the manifold on all of our cars would be...
Its water cooled, an exhaust isnt.
If you read the rest of the thread you see full race has recommended not running an aluminium dump pipe either, and that although a cat back could be alloy, it will eventually crack/break due to the thermal expansion.
Albert
May 13, 2009
1,710
Tempe, AZ
I really doubt it will melt. maybe fatigue over a period of time. possibly crack. we'll find out tho.
Sir_2jza70
Sock puppet master
May 10, 2005
53
Canberra, Australia
Yeah "melty" was the word I used, it was an exaggeration. I didnt mean to suggest its literally going to melt all over the floor. All metals lose their strength way before they melt, this is the issue. Aluminium also has the issue of high thermal expansion, twice as much as steel.
stevenr816
932
Phoenix,AZ
Again I'm now going to run a SS downpipe and aluminum back. It will be straight aluminum so easy to replace if and whenit goes out. Since I already have a 4" vband set and bends I'm going to make a aluminum Downpipe for the track
Tire Shredder
569
Oshawa
aluminum melts at roughly 1200 degree farenheit. The chances of your EGTs exceeding 1500 degrees are almost guaranteed. the oxide that forms will melt at over 2000 degrees
terrible idea. good luck with that for any length of time. it just seems like it's so much more trouble than like 8 lbs is worth. it's a headache and potential liability. if those welds let go around the V-band when you're doing a pass on your not-so-perfectly tuned 1200hp car and hot gasses (probably flames) get spewed out from the turbo into your engine bay, it could get ugly.
stevenr816
932
Phoenix,AZ
Again there are plenty of people I know running an aluminum exhaust on drag cars. 1000+ hp civics, alot of outlaw v8 guys, and obviously you didn't read all of our posts. Yes it melts at 1200 degrees, but exhaust gas isn't direct heat it's indirect.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Hey Steve, thanks for the link in my email. Looks real good so far.
I have made girdles before for the billet mains, here are pics of the one I made for the malta dragster
mk3_7m
536
melbourne
^^ i didn't know you had these...... Unless these were custom made then ok.
Anyway goodluck with the build :D. Make us 7m fans proud ^_^
stevenr816
932
Phoenix,AZ
Trust me I will :) it will be nice to have a high HP 7m in the states.
hornet7288;1739234 said:
great build. Subscribed for progress
Thanks
Pokey2301;1739249 said:
subscribed!
Thanks
Sweet I'll have to talk to you about making one with the TMS Billet mains.
Supra28
Supramanian
Aug 17, 2006
1,921
Columbus, OH/Kansas
Sick build. The valve covers are badass....AZ seem to have quite a few powerful 7M's from what I've gathered. I'm glad you chose the 7M power plant to try to achieve such power as it always seem to be a "In your face!" matter when done successfully haha.
Is this car going to be strictly for drag or occasionally driven on the streets?
stevenr816
932
Phoenix,AZ
Ya there's a couple cars out here that make decent power. And it's going to be purpose built for drag but will drive it on the street as well as occasional drift and road race events.
stevenr816
932
Phoenix,AZ
New parts came in today.
SIP Solid Timing Tensioner
SIP 1.3mm MLS HG
Gates Blue Racing Belt
TMS Adjustable Cam Gears
The solid tensioner looks a million times better then the stock one, any 7m I build will definitely have this on it.
stevenr816
932
Phoenix,AZ
IBoughtASupra;1741191 said:
Are you building the 7M 1000+ motor or is Rich doing that? This motor pictured here is just to keep the car moving?
The block pictured is to get the car moving. I'm picking up my $5k head Friday from the machine shop which is going on this block. That heads just for mock up completely bare. Rich will be building the block when I get more money saved up.
