Which strut bar would you use?
Which Strut bar would you use?
  • Cusco Aluminum/ Carbon Fiber Bar
    Votes: 15 39.5%
  • TRD Strut Bar
    Votes: 23 60.5%
  • Total voters
  • Poll closed .
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
I think you might just have to cut out some of the bracing on the underside of the hood. Im alright with doing that. For the most part im just trying to figure out which looks better. They will both function the same.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i ahve all wasy lied the trd one but
if i ever got the cusco one i whould make it tri bar cause that whould be freeking pimp
werewolves182
Aug 23, 2005
436
Crownsville, MD
So in order to use the TRD bar, you have to turn it 180 degrees? Do you have to modify the hood at all or was I correct earlier in saying you have to remove some of the hood bracing?
SupraOfDoom
Starcraft II ^^;;
Milwaukee, WI
I like my Cusco's ..
Adjuster
Neither the TRD or Cusco does anything on our cars. (We do not have a typcial strut front suspension, so there is nothing to be gained.)
If you want to make some gains, you need to tie the strut towers to the fire wall/cowl area. (That will make a large difference in how much the vehicle flexes.)
Zach
ECUMaster USA
Apr 6, 2005
375
TX
The TRD bar does NOT bolt on, no matter which way you turn it. It requires a good amount of cutting/welding/repowdercoating. It's really not worth it, just get the cusco bar and enjoy putting it on in five minutes.
