Which Rims for DragRacing?????
Tun_x
Built to do the NASTY!!
Utah
upgradedsupra said:
Ok ok..but can you lower it? That thing is a 4x4 dude! Would they fit in my car?
Duane
I can't lower it with the 28" but I can on my new 27"s ....
Tun_x
Utah
I took it off some sweet jumps back in the day!:biglaugh:2900lbs before the cage
slow_yota
Gotta Pay To Play
Tun_x said:
welds 15x10 with a 6.5" backspace and a 28x 12.50 slick.. mmmmm thats the good stuf..
This is th tire that you will need to go faster than Duane
Dood ..I am Lovin That look..Any rubbin on the rear fenders ?
[corners or bumps]
bowsercake
828
Irvine, Ca
Tun_x, are you lowered? It doesn't seem like it but I'm trying to gauge how a 27" tire would fit on a slightly lowered car.
Those tires look good though. Any videos of you at the drag strip?
dbsupra90
toonar
indiucky
27" will work w/ eibach springs. its real close tho, but still doable.
jag- 26x10.5x16. full on slick you will need one step lower on the width (slick is measured tread width, not section width)
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
^ truth.
26x10.5 ET Street = 26x8.5 ET Drag
2jzmk3
Guest
i think for most of you guys the stock mk4 TT wheels with either mt 275-40, or m&h 275-50 will be really good, and they will clear decent size brakes. Duane what size are you running out back? 4 piston 13in?
i just went 11.9@141 with the 275 -50 m & h's i bogged pretty bad, or it would of gone low 10's easy.
Tun_x
Utah
I'm slightly lowered ... I'm on D2 coilovers so I have allot adjustment... No videos yet .
2jzmk3
Guest
annoyingrob said:
How's the drivability off track with those? I may just swap my rears permanently.
dont know i dont drive around on those. victor from f&h will be a better person to ask since he drives on those all the time. but i wouldnt drive on them in the rain, its a little scary, especially if you are making HP.
AGlobalThreat
Acceleration
Apr 4, 2005
991
Santa Clarita
2jzmk3 said:
dont know i dont drive around on those. victor from f&h will be a better person to ask since he drives on those all the time. but i would NOT drive on them in the rain, its a little scary, especially if you are making HP.
Fixed ;)
Getting a seperate set of wheels for the track will extend the life of the tires dramatically and you'll be able to have that serious grip at the track without compromise when you need it. If you frequently drive on the street you will most likely save money in the long run by buying a seperate set of wheels to mount your drag tires on.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
I have 3 sets of wheels for my Supra right now actually :) Summer, Winter, and Track. The reason I asked is that I have grip issues on the street. If he says they're deadly in the rain, that's reason enough for me to NOT run them all the time.
