where to route isc plumback hose
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
so i'm ffi now and using a 1uz throttle body. On the bottom of the tb is a port and stock the isc routes back to the intake after the afm. I was thinking, well what difference does it make being before the turbo and after the turbo? Could i just route it to the tb? It would be a lot cleaner.
cliffnotes:
Do i have to route the isc back pre turbo or can i put it straight into the tb?
Thanks :D
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
It is a pain in the ass that there are all those hoses that have to be routed over the engine, isn't it. My suggestion (which I will be doing myself) is to have a look at the routing of the ISC on a 2jz-gte engine - their isc valve is in approximately the same location, so I would assume the piping would be similar.
lintlars
ROOTS RADICALS
Ft.St.John BC
Ive been running mine like I stated for two years, and it has a one way valve thats stock on the 7m ISC (its the small washer with rubber that goes between the ISC and the flange) to avoid pressurizing the unit its clean and Ive had no problems
staticpat
Supra Chair!
Birmingham, AL
Yeah that sounds like a much cleaner solution. It's not like you'll need the ISC when under boost anyway. There shouldn't be any harm in routing it post-turbo with a check valve.
