ryansmith;1892025 said:Thinking of lowering my car more with the 17x9+35's 225/45/17 but they look like they will definitely rub, it's quite weird... I assume they will naturally come in camber wise the lower you go correct ? drft's pics is where it's getting me confused, his fit but with mine they look as if they will go directly on to the fender when I drop it more...
Camber will change but not as much as you think.
With those sizes you shouldnt have any rubbing issues other than the fender liner over bigger bumps.
And your tires are stretched so unless your car is basically on the ground your never going to hit the wheel with the fender unless on some stupid shitty suspension.
