oldsking
789
Chapel Hill, NC
Heres my current setup, 5zigen FN01rc's 17x9 with 225/40/17 up front and 17x10 with 245/45/17 out back. If I remember the offset in the front is +20 and the rear is +12
oldsking
789
Chapel Hill, NC
They rub a little but I have it lowered the most I can for now. Only on hard bumps it rubs but not bad.. I plan to roll the fenders and pull the rear out a bit
KaliSupra88turbo21
Ventura, CA
alright so this is what i did im having my 18x8.5 235/35/18 front & 18x9.5 245/40 18 in back all 4 wheels 35+ offset im hoping this fitment is a good fit for my supra thers no more changing size tires they guy wont let me its a done deal, so if anything is this the a decent fitment of not let me know i can roll fenders? or do i have use a camber? need help im getting them on tommorw at the shop so id like to know more info on this subject' guys help me out pleaze, thankz.
alex's_mk3
29
Hawaii
Here are the XXR 521 18x8.5+25 245/40/18 18x10+25 265/35/18 Gold from next level motoring. Had to roll the rear fenders ( was rubbing )me 002.jpgme 004.jpgme 005.jpg
Reg
68
Nashville, TN
Hey alex can you upload some more pics of those xxr 521's, Ive been wanting that style for about a year but never knew how they would look on a mk3. Im definitely liking them. Plus what is your suspension setup?
drft
az
here is some pics i have of my 521's on the mk3.
18x10 +25 all around with 225 40 18 on jic coil overs no fender work, tire tucks in nicely just wish coil overs where stiffer
ryansmith
541
New Zealand
ska_ponch;1890912 said:
How would Rpf1 17x8 +45 17x9 +45 work out on a 89 mk3
Go with 17x9 + 35 all round thats safe and wont rub at all depending on tire, 225/45 17 is what I have on my 17x9+35 and wont rub at all, check the post above me even he clears with 18x10+25 all round
18/10 25 here to 255 front and 265 rear. 275 fits fine in back as well. 265 up front rubs when super slammed. Can fit 295 rear and 285 front if the slam in not super aggressive.
ryansmith
541
New Zealand
Thinking of lowering my car more with the 17x9+35's 225/45/17 but they look like they will definitely rub, it's quite weird... I assume they will naturally come in camber wise the lower you go correct ? drft's pics is where it's getting me confused, his fit but with mine they look as if they will go directly on to the fender when I drop it more...
alex's_mk3
29
Hawaii
It's on Tokico shocks and Eibach springs for now.. I just got me some Megan Racing Coilovers that I have to install..
Camber will change but not as much as you think.
With those sizes you should have any rubbing issues other than the fender liner over bigger bumps.
And your tires are stretched so unless your car is basically on the ground your never going to hit the wheel with the fender unless on some stupid shitty suspension.
