What suspension parts do you run
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
I am trying to find out what I want to do with my suspension THIS IS NOT a which is best thread im merly trying to see that you guys use and WHY and i will make my choice on the info you give me and that info from other web sites
Anything from coilovers to roll bars
thx guy
Robert
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
As of tomrrow I am running some HKS TEMS struts and springs.
HKS TEMS controller
Everything else is stock as far as I know. Next thing Im looking into is swaybars and front and rear strut bars!
koulee
497
Tanabe front sway bar only atm, but I will eventually get the following:
Tokico blues
RSR Race Springs
Beefier endlinks
hot dayam mk3
149
bilstein struts set on lowest purch
old school full linear st springs
tein pillow ball mounts all around
kyb bump stops with dust boots
mkIV TRD front strut bar
tanabe sustec sway bar F/R
soon to get
A-1 traction, and toe arms for the rear.
drjonez
the motor city
www.4cefed.com
tein RA coilovers- Al bodies, mega stiff spring rates, EDFC fun
ST sway bars- bought 'em yrs ago, drastically reduce body roll
nylon bushings- because rubber sux, less compliance in bushings means the sus is actually doing what it's supposed to...
steel front/rear subframe spacers- further reduction of compliance
cusco STB- stiffy
JIC lower arm bar- sem-stiffy
EDIT: added some stuff i completely forgot....i'm a moRAN....
born2drv
1,199
Burbank, CA
Tokiko Illumina II Electronic Struts
Eibach Pro Springs
Cusco Front Strut Tower Bar (Chromed)
Cusco Rear Strut Tower Bar
LIPP Front Strut Tower Steel Spacers
Suspension Techniques Front/Rear Sway Bars
Floor Strut Bar (Chromed)
Also installed brand new rack and pinion, wheel bearings and tie rods. I can't tell you the difference it made. All vibrations were completely gone, it handles amazingly well. I didn't even recognize my own car when I took it for a spin afterwards, now I'm more used to it but it still amazes me.
Mind you I think if I had to do it again I would ditch the TEMS... I still love the concept of electronic shocks, I'll get a different setup some day that has more of a dramatic effect. And I still have to stiffen up my floor strut bar by getting stiffer mounting points on the frame, that will get done when the body work gets looked after.
I
itr206
Guest
At the moment I only have Tein Flex and an Ebay strut bar given to me from another member.
My car handles pretty damn good. Not too harsh, but good enuff to throw it in some hardcore turns.
Coilovers are the only way to go in my eyes for the adjustability alone.
I picked Tein because they have been proven many times over.
Next season I will have a cage in the car too. Should stiffen it up a bit
supra90turbo
shaeff is FTMFW!
33
MA, 01440
Bilstein Struts (because they're Bilstein, and height adjustability was enough to make me buy 'em)
ST Springs, because I did some research, and read positive information about them. I was happy with my purchase.
SS Trac arms because..... no explanation necessary really...
JIC Lower Arm Bar because it was cheap!
Greddy FSTB, I liked it, that's about it.
Uber rare OOS Hatch Bar :icon_razz
bgrieger
Toronto
Tein flex, for adjustability, separate ride height and spring preload, Whiteline sways, because the flex are a bit too soft. Should balance the car nicely for the mainly street use the car gets, still letting me play on occasional lapping days. If I were serious about tracking, I’d use a softer sway (stock perhaps) and something along the lines of the Tein RA’s, or have the flex setup stiffened up with new springs and valves.
Can't say it enough...sticky rubber. The easiest way to better cornering is bigger, softer compounds. I run Michelin Pilot Sports, but there are several other good tires out there!
kysupra
I'm Single
Apr 25, 2005
72
Lexington, KY
well most of it is still setting in the garage wanting to be put on but...
whiteline 40mm Front swaybar
whiteline 28mm (i belive) Rear swaybar
Nylon bushings
Hatch Bar
BFG KDWs
still to order
Front STB
Rear STB
Strong end links
bigaaron
4,692
Pomona, CA
www.driftmotion.com
JIC FLT-A2 coilovers
Suspension Tech. sway bars (rear links on center adjustment hole)
Cheap shock tower bar (cause it's shiny aluminum)
Falken RT-615 tires, I freakin love them.
Great handling with the exact spring rate I wanted. Very good manners. No understeer, and oversteer only when I want it.
