What have you all made/ used for...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
...For the rear swaybar endlink tabs?
Was just replacing my differential, and when I climbed under the car, I noticed that my left read endlink mounting tab was busted clean off. I know that some people just weld the originals to reinforce them, but have also read(don't remember where) that others use a new piece of steel of greater thickness. Do you guys just cut a thicker piece of metal stock, or did you use something pre-existing?
Thanks.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
Here's my busted tab:
And another gem I found while under there:
After cleanup:
New vs. old:
So now I HAVE to get a guy to come over to weld up this crack before I put the other diff in- Luckily, the crack did not continue to the other side of the subframe- it's only about 4 inches long.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
So my buddy is driving across town(true friend) to weld this up for me.
I also removed the control arm, and am going to have him weld the tab back together, and reinforce it with a washer welded to each side of the tab. Hopefully, that'll give it the strength it needs.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
Thanks Poodles- I'm going to try the double washer reinforcement, and see if it'll last. If not, I guess I'm headed to BIC. The diff is not rebuilt really, as I didn't mess with the clutchpack, or the bearings(they seemed to be in smooth, quiet shape). All I did was replace the three seal and check/adjust the pinion preload.
From what I read when they raced them in stock form they broke. One of the only shit moves Toyota has done was to put plastic endlink instead of beefing up the tabs...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
Well, dunno if it was the old diff, or the crack, but the rear end 'clunk' that I used to get when I got on/let off the gas is totally gone. Happy happy, joy joy.
