Wastegate size, Tial experiance?
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I need a new wastegate and I'm stuck between the 38mm and 44mm Tial's.
I'll be running a GT4088, BC 264 cams, and fuel system to support 600whp. I'm mostly concerned is the 38mm going to be too small? I don't want to creep and have to buy the 44mm in the end anyway.
The price difference is quite a bit, over $100 from most vendors. My manifold is flanged for a 44mm v-band, but even buying the 38mm WG and adapter would be much cheaper.
Any recommendations for wastegate's at this power level? Thanks.
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
I would go with the 44mm. It will flow enough no problem.
the 38 might be ok but it might also cause creep. So i would be safe and spend the extra money the first time around.
quake
toyota tech
Apr 13, 2005
619
r.i.
i have used both you will need the 44mm to control boost properly with pump gas and a turbo that size.
