Walbro fuel pump upgrade - is 12V mod required?
scotty
476
Norway
scottnicholas.net
Hey,
I'm about to install the walbro fuel pump.. and wondering if I really need to do a 12V mod? What will happen if I use the stock wiring?
I've got no plans of tuning or such, only running Lexus AFM, 550s, AFPR. Just installing the walbro before selling the car.
Scott
toyotanos
What will we break today?
2,844
Coon Rapids, MN
Its not a bad idea to run the pump at 12v at all times, most AFPR's should be able to handle the extra flow (unless its a really small, cheap one) might as well be a little safer and make sure you don't run out of fuel in the mid-range!
digihonk82
118
Olathe, KS
I took my resistor out b/c at idle I could hear the Walbro in my tank struggling with the 9volts. Works great. Gas mileage suffers in the city.
shaeff
Kurt is FTMFW x2!!!!
11
Around
The only real reason to do this is when tuning the car, it takes out the "unknown" of the voltage switch from 9 to 12v. That switch is a pain to try to tune the car around.
If you don't tune the car, I'd leave it as-is, personally.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I looked up the Walbro specs and at 50 PSI it can pull around 10 amps. I would be a little wary running that on all the stock wiring. I don't know what gauge the wiring is but I don't remember it being very big.
shaeff
11
Around
Anyone doing the 12v mod should be running something along the lines of 10 gauge wire along with a new relay. I just don't trust the old wiring anymore.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
The pump still runs at 12v under certain conditions, potentially overloading the circuit, I wouldn't do the Walbro pump without the 12v mod with larger gauge wiring that shaeff mentioned, then again I haven't crunched any numbers for what the stock wiring can handle.
scotty
476
Norway
scottnicholas.net
Thanks for replies so far.
So it's OK to just swap fuel pumps, and use stock wiring / not doing any changes what so ever? Not doing any tuning, just want the car to run smoothly without fuel cut.. main goal.
Basic mods worth mentioning:
Lexus AFM, 550cc's, AFPR, 2.5" IC pipes, Apex-i filter, 3" radiator, 3" exhaust.
What base pressure should I set it too?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
I've run my Walbro without the 12v mod for 5yrs now, but I only boost to about 12psi max, and it's tuned rich.
When i go to a T-4 after the summer, I'll be doing the rewire. And as Shaeff pointed out, the 9-12volt switchover does play havoc
with AFR adjustment when you're going for max power.
gte-power
ny
hey guys i'm not really familia doing electric stuff on my car...but i think i really need to do this mode to my car to
since i'm runing 15-psi my car on top end start to run lean..and i do have a walbro in my car!!!!!!!!!!
i have 1jz in my 89 supra...can some post here the instruction how to do it plz
thank you so much
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
^I know there are instructions on the site, search for them. I can't find them right now. I just want to make clear, the only reason to do the 12V mod is for tuning purposes, though at 15psi, you SHOULD be tuning if you aren't already. Running lean at 15 psi on a stock turbo is dangerous.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
He's not running a 7M. 15psi on the 1J isn't all that much.
IBoughtASupra
4,455
Queens, NY
thank you so much
Are you on stock 370CC 1JZ injectors? If so, 15 PSI is not really safe. If you are in a single, it's even worse.
Get a bigger set of injectors and something to tune with.
