V8 Supras
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
So I'm making this thread cause I want to see all the diffrent V8 swap'd supra's.Show what motor,tans,wireing set up you are runing,what it took to make the swap work and please as many pics as possible.I also whant to see what you to post what motor set up you feel is best for the MKIII and why?I also want weight specs on all motors and trans if possible.Thanks Guys and I hope that this thread gets a lot of hit's for any one esle who is wondering about doing a V8 swap themselfs.
jake breyck
33
fl
Here is mine, 1uz-fe stripped of all non essentials, W58 transmission
Gritz
155
nc
Never seen it done, but the nissan q45 is a strong motor...puts out more low end tq than the 1uz..Lt1 is a good motor as well as the ls1..depends on what kind of money you want to spend..any of these motors can makes some serious power boosted....I think the 1uz is the high rev king of the bunch though...
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
The smoothest operating high power efi v8s will be anything with a coil pack design. This eliminating the lt1. If you would consider that, pretty much any v8 is on the table.
If you could source a 4.6 dohc from a cobra that would also be an ideal setup. Possibly with 5.4 bottom end? The aftermarket support is double nearly everything with the exception of the ls1.
I myself am considering a 1uz with a progressive rate 150 shot direct port for a drift car and extremely cheap 320-350whp.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
Well I am looking at a light motor,that rev's high,and a motor that sits nicey in the supra for good weight balance.I'm looking for a all motor set up.
Gritz
155
nc
in that case ls1 or ls2... ls1 is 350hp stock....my cousin found a ls1 SS camero( those are 375hp i think) clip for $2500 and thats even with the t56..can't beat that...
Gritz
155
nc
MK3.0dudeman;1235147 said:
and than how much money to make it work in a supra?Let me guess a lot:biglaugh:
Look to pay $3000-$4000 for a ls1 and t56 trans...hummmm maybe it would be better to go with the 1uz...but getting 350-400whp will be tough with out boost..sure it can be done.....prolly be radical though..i say 1uz with boost for the cheapest quickest alternitive...anyone else??
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
1uz will be extremely cheaper. You could do a 1uz with 150shot for the same price of the ls1 engine alone. Good luck getting a t56 for a swap included with the ls1 those only come from ws6 firebird and ss camaros and corvettes. Like I said prob 5k for that setup. You could do a twin turbo 1uz for that cost. Remember you would need custom mounts all around. It's just not worth it unless you're rich.
jake breyck
33
fl
I have around 3grand in my supra Total Buying the car swapping in the 1uz, if i wanted a ls1 i would be only have saved half on the motor and have no car!
Keep it toyota!!!!!!
SAS
Dark Cloud Drifter
Jan 13, 2009
7
Clewiston, Fl
my old MKII supra but its a buick nailhead 350 with a TH350 trans. Solid motor and tranny mounts no ac no power steering. used as a drift car it made 602 hp with a 1600cc carb. forged pistons, rods, knife edge crank
SAS
Dark Cloud Drifter
Jan 13, 2009
7
Clewiston, Fl
eman2289;1239666 said:
I hope to god that u purposely riced that thing.
what is riced out on it? everything is stock except the hood scoop which had to be made to get air to the carb. The exhuast is boso not rice and thats how me roll down in south florida. We build outlandish shit
A piece of unchromed crush bent pipe is hardly either..... :nono:
