Urgent lubrication question
josbeat
483
spain
IJ.;1971704 said:
With a scraper unless you have 40+ Psi Hot idle pressure you're running the risk of increased Piston/ring/pin wear...
I can rise up the pump speed and adjust the maximum pressure is another good think of the dry sump system
thanks for all helps.
FredMk3
mk3 for life!
Sept-Iles/Quebec
So IJ, do you advise not running a crank scraper on a 7M?
I got one on my engine for like 5 years, I'm tearing my engine right now, will remove it its preferable.
Welcome!
It's fine if you can make 40Psi on a hot idle Fred so the Squirters are open all the time, some after market rods don't have the beam holes, for a road car that spends a bit of time at low RPM or idling it needs some splash, but if you're running stock rods the spray holes in the beams lube the bores so it should be fine.
josbeat
483
spain
news
today I been working on it and I found like it still making more pressure when is hot than cold
and that could be by the oil feed pipe diametre, AN-12 when it is recomended to be AN-16 when is more than 5 feets longer
or the oil feed pipe routing is no the ideal because it goes up just on the exit of the oil tank (easy solution)
and or like some of your said the 10w60 is to heavy when cold
I always asking me way on the Nascar they are using oil heater on the oil tank ? the answer maybe is that , to get a good fluidity for the firt start , the Nascar cars also have the oil tank at the back of the car like mine so....
josbeat
483
spain
now its to late
two cylinders are damaged , two cylinders have 30 psi les than the rest the 3º and 4º
I will try to see what was the problem so I will use it to get the system working propelly and then repair the damaged next year.
really the problem is the little time I have to have it ready before the last race of the year because inside me somehing are telling me that the engine its not right , thats way the reason of this Thread
I will send an email to Pauter to ask way his Beatifull rods don`t have any oil hole or grains to send oil to the pistons.
josbeat
483
spain
I need to drill the oil squiters to let them free
and anothe oil tank with AN-16 in and out conections
with a little more speed on the pump it will be fine.
will keep updated
regards
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Don't drill the oil squirters unless you don't want oil pressure in the rest of the engine. The oil squirters are pretty close to the start of the oiling system, so if they don't hold pressure, you won't get any to the rest of the engine.
Edit: As per thie diagram here:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=LU&P=2
The "check valve" there is the banjo bolts spring. Drilling that out will reduce available presure to the crank and cylinder head (and turbocharger.)
josbeat
483
spain
can we talk about it?
yes I know and thats way I will change the pump pulley to get more pressure.
on that diagram we can see the lubrication of the pistons are by conrods or the squirters so now dont have the conrods oiling ... the only way is the squirters .
will not be a big diference no? no hole on the conrods , hole in the jets, one for other
josbeat
483
spain
Nick M;1972288 said:
You are also using oil that needs far more heat to flow than you might be generating.
I replace it for Shell 5W30
and the feed pipe will be bigger. (thats was the problem)
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I think this engine might develop enough heat...oil temp on my M3 maxes out at 270F on track (S65 V8). The 7M will likely run considerably hotter.
FWIW, the 10W60 TWS shears to 40 wt. and then stabilizes relatively quickly after entering the engine. I was actually consuming .5 quart per track day in my M3. Switched to a blend of Redline 10W60 and 5W40 (to match kinematic viscosity of the castrol) and the consumption stopped.
As far as the feed pipe is concerned, do a hydraulics calculation on how much pressure you actually lose with the OEM piece vs ARZ or equivalent. You'll likely find that it isn't much.
8,873
If he is using synthetic, then the grade will not be as crucial. BMW specifies something like 50 if I remember. And it is grade, not weight. Gravity has nothing to do with it.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
40 wt. as in SAE grade (i.e. 5W40). BMW specifies Castrol TWS Motorsport 10W60 for M cars, the same stuff that josbeat is using.
8,873
adampecush;1972686 said:
BMW specifies...
For the record, I couldn't give a shit. Using oil that needs a tremendous amount of heat to flow (viscosity changes with temperature) sped up the demise of his engine. Not squirting the cylinder walls is secondary.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
intresting dry sump limted wall lube at low rpm
only thing I can see I kinda skimmed thread
1. notch rods mosty likly all ready side
2. re jet your oil squirtes and remove check ball and spring (most liky have to get some pretty good with a tig welder thou) honda's do this they have no check all or nothing
toyota's race team didn't even run the oil squirters and just used jetting from the base of the rod
on my old motor wet sump
I rand a crank scarper teflon very high clearance thou , eagle rods with no oil jetting and I removed the oil squriters
after the tear down my motor had plenty of oil main reason there still was splash lubrication just limted and there is rod bearing bled out it just not controlled well
so you do have oil going on to you walls since the crank will still throw it up there just not controlled
when I pulled my motor apart my ring's were good and so were my wrist pins so were the upper rod baring sleavs (stock machine marks) there's oil on dem walls
granted this motor's ring's and wrist pins were were out faster but that's what ya do when ya wana shave some oil off the under side of you piston and keep you crank oil tornado free to gain just that extra power
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
It's a matter of where in the chain the holes are.
The squirters get pressure early in the chain, so a pressure release there reduces available pressure to the main bearings, rod bearings, cylinder head, and turbocharger. The slots in the rods get pressure AFTER the crank, and rods, so a release there has a much lesser effect on the cylinder head and turbocharger oil pressure, and no effect at all on the pressure to the crank and bearings.
josbeat
483
spain
yes I agree with you but on the other side the most critical when cranking is the pistons and cylinder walls so if the first place to get oil is the pistons and cylinder walls will not be bad , and then the rest .... sincerelly I think it will be the best because plenty of oil kept inside the crank and bearings and inside camshaft journals but not on the cylinder walls so....
one good thing with the dry sump is that I can put two bolt to hold the pan and test and then if its right seal it again if not remove two bolts and change the squirters again .
the bad thing is the amount of silicone with the crank scraper we need to remove , a lot jejeje
anyway this engine need to be repaired again so we can use it like a test unit, but making the pump turning faster I can get the amount of oil required like Ij say but it will reduce some power, the best if to get the correct oil pressure needed to run the engine safe but not wasting more HP of the necesary.
tomorrow I will report the results, the test will be to replace the squirters by other drilled (not completelly free hole) with the same configuration in the pump and check what is the oil pressure variation.
josbeat
483
spain
sorry my friends forget my last post.
I will not change the squirters.
I will wait for the new set of pulleys to rise up the pump speed but not before I had replaced the oil tank for other with better deaeration and with bigger conextions.
looking the tank feed hole I have now (5/8 BSP) is to small so I am pretty sure that the problem is the cavitation.
will keep this thread updated
josbeat
483
spain
after new oil tank with bigger holes (AN-16) new oil lines (AN-16) and new pulleys (20-40 before 21-38 now) I got exactly the same presure and that is not the most extrange.... cold and hot is exactly the same oil pressure also adjusting in the relief pressure bolt two turn inside still same!.
idling- 35 psi , 3000 rpm- 45 psi and a plenty of vaccum thanks that I have a vac regulator.
i dont know... maybe the press sensor is bad ¿!?
