two left over plugs?
knucklebuster
29
St. Louis
I am rebuilding my 7m-ge, i had some block work done on it at a machine shop. When i got the motor back i got a small box of parts that i did not take out of the block (plugs, bolts, etc...). All i have left are these 2 small plugs that i CANNOT figure out where they go. Any help would be great
One will be for the oil gallery at the front right side of the block behind the power steer pump the other will be the same gallery but at the back as pictured. (blue arrows)
stomis
NA Die Hard
Mar 22, 2010
68
Jersey Shore
IJ.;1555617 said:
Never seen any evidence of it in my engines Stom.
Alright good to know. Seen some homebrew fixes before with npt fittings and high pressure lines tapped into the galleys but I was just curious.
By the way does a turbo oil pump flow better than stock NA when I build my motor or should I be looking for an aftermarket?
Always ran the stock internal hardpipes and fittings here with 0 issues, never seen any evidence at all to support the "fixes" people sell so figure if it's not broken don't fix it.
GTE Pump has longer gears for more volume per revolution, in an NA consider it a High volume pump, none of the after market pumps are "better", one of the Vendors was selling clearenced and coated GTE pumps awhile back and depending on how good their work was that would be an option.
Always prepped my own ;).
