Torquing Crank Pulley Bolt on an Auto
JDMMA70
2,550
Houston
Need help with torquing the crank pulley on an Automatic supra. All searches lead me to how to do it on a 5spd. So that won't help me hah.
Thanks for reading
~JDMMA70
you jam a screw driver in the ring gear for the starter or get a chain wrench and hold it inpalce. i like the chain wrench better and there like 25 bux at harbor frieght but dont get the one that you attach to a beaker bar its one link to short i think the actual one fits.
JDMMA70
2,550
Houston
IJ.;1258322 said:
Screwdriver in the ring gear it is then :)
Thanks IJ, call me stupid but im looking at the TSRM at the Starter looking for the ring gear. Is it under a different name perhaps, im looking for it so I know where to jam the screw driver.
Thanks
~JDMMA70
You'll need to remove the dust cover on the front of the bellhousing to get access from underneath.
Get a friend to use a BIG screwdriver against a tooth and the bottom of the block while you torque it down. (4th pic)
