Tookwik's 7M-GTE COP ignition mod w/ stock electronics...pics and writeup
SolidStateS15
researcher
Jan 11, 2007
8
Southern MD
935motorsports said:
We can have wire made up in 8MM if there is interest.
should make us a prototype kit and price so we can see :love:
i'm still waiting to hear from magnecor, hopefully today. i'd like to see what both of you have to offer.
8,898
Cannablizing the harness is good. Looking like a hack job is bad. I really do like this unecessary mod. And that isn't normal for me. Great job!
turbogate
Life is Boost
May 18, 2005
425
South, FL
Quick Question, what about the actual IS300 coil pack harness? is it incorporated in the main IS300 engine harness? If not, Could we not just use that since I assume it would already be longer/extended? just wondering.
Thanks
marc3
canadian blood
Jul 19, 2006
229
quebec,canada
god damn, i've been looking all over for these coils, not a common find in a salvage yard. guess i'll be buying mine new.
SolidStateS15
researcher
Jan 11, 2007
8
Southern MD
could someone do me a favor and get me the lengths of the plug wires? are they all the same? could you measure just the inside cable(between the ends), and then the overall?
thanks
90T04
Tucson, AZ
www.azsupras.com
Yes, make them please... Ill buy them asap.
I made some test passes tonight with the new setup and at around 5000 RPM it sounds like Im hitting the freaking 2 step. I dont know if its the coils or the wires, so im going to start with the wires.
90T04
Tucson, AZ
www.azsupras.com
thanks
Heres the 3 lengths:
Overall
Short: 10.75
Medium: 15.5"
Long: 18"
Just the wire
Short: 7.75"
Medium: 12.75"
Long: 15"
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I can't believe how plug and play this is...
I'm in awe at how amazingly simple and ingenious this really is.
Tookwik, you certainly are a god amongst men! ;)
I can't commend you enough on this find, and you shall definitely be remembered for this.
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
getting this punched out at work in the next day or two:
this will cover the plug valley and the indents in the valvecovers. i didnt put holes in it becuase im not sure how imounting it yet, becuase i shaved my valvecovers...
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Jeff Lange said:
I assume you mean jt2ma71? He has sequential ignition with a standalone.
yes jt2ma71 can you run sequentil ignition with out standalon I also sent jt2ma71 a p.m. to have him make me one of those FFI's of his is there a nuther way to get his attention:biglaugh:
nerfkhat
168
centennial, Co
so let me get this straight all i do is lengthen the harness to reach the coils? and the plug wires go in the same place as stock ones? Tukwik can you make a diagram of which cylinders the coils go into and the wires from that coil to whichever cylinder? im sure some people maybe confused other then myself..
Jeff Lange
Administrator
4,919
Sunnyvale, CA
jefflange.ca
Coils go on cylinders 2, 4, and 6. Wires go from 2 to 5, 4 to 3, and 6 to 1.
(At least, this is the 2JZ setup, you could also go 1, 3, and 5 for the coils I would think).
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
For the best mounting configuration, I put them on 2, 3, &6. But what Jeff stated for the wires is correct.
turbogate
Life is Boost
May 18, 2005
425
South, FL
Without confusing anyone. For Looks only, since it is waste spark fire. It wouldn't matter if I then have the coils mounted on 1st, 2nd and 3rd correct? as long as the wire then goes from 1 to 6, 2 to 5, and 3 to 4? or does where the coil sits in that combination matters? Since the main purpose of this mod is more convenience/cleanliness, then functionality. For me, it would be nice to have them on 1,2,3 or 4,5,6. Off course that's assuming I could find a way to secure them. on those locations. Again sorry if that sounds confusing to some.
PS. I found my coils for $75 all 3 (Used of course)
:biglaugh:
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
:biglaugh:
From what I remember, they just won't fit like that.
