Tlo86's 2JZ Build Thread..
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Update *aug 22 2007*
Update *aug 28 2007*
Update *aug 29 2007*
Update *sep 10 2007*
Update *Jan 8 2008*
Stage 1
r154 $350 parts car
r154 driveshaft $90 supramania.com
1jz r154 bellhousing $350 driftmotion.com
1jz r154 flywheel $269.99 driftmotion.com
ARP flywheel bolts $31.50 driftmotion.com
t4 turbo manifold $100 ebay
2jzgte from an aristo $2100
1jz oil pressure gauge sender adaptor $20 driftmotion.com
used driver side front fender $20 parts car
used front mudflaps? (old ones rusty, used ones like new) $20 parts car
coin tray in place of TEMS buttons :) (Yeehaw found it!) $free parts car
used door lock cover (inside, the one with the shitty clips to the door, have to figure out how to make them stay on...) $free :)
1jzgte (supra) upper oil pan $150 for everything supramania.com
1jzgte (supra) lower oil pan
1jzgte oil baffle
1jzgte oil pickup
2jzgte oil pickup gasket $8 toyota dealer
2jzgte thermostat from toyota + gasket $too much. 27$ toyota dealer
used interior trim piece for center (around deck holds cig lighter etc) $10 parts car
**earls clutch line $20 supramania.com
**toyota oem clutch hardline turbo long $dont remember toyotapartscheap.com
**toyota oem clutch hardline turbo short $dont remember toyotapartscheap.com
**bought a full clutch line from driftmotion.com for about 45$ ... sick of the hardlines =/ heh
new Clutch master cylinder $40 toyotapartscheap.com
new slave master cylinder $58 toyotapartscheap.com
Manual transmission pedal set (clutch, brake) $25 i think supramania.com
new 2jz starter (ive actually had this since i owned my mkiv i just never put it in) $dont remember toyota dealer about 6 years ago
used hood bumpers on front (they look better than a blue hose holding it) $free parts car
walbro fuel pump (255 lph) $98 driftmotion.com
new pleather shift boot $15? supramania.com vender
shift knob 65$- i bought this from another vender here its a MOMO and it looks sweet.
marlin crawler shifter seat $10 marlincrawler.com
marlin crawler socket $8 marlincrawler.com
BIC solid motor mounts for 89+ mounts for a jz engine :) $185? BICperformance.com
speedo cable for r154 (not actually sure if i needed this but it was free so who cares hah!) parts car
RP gear oil ( i actually bought this for my lexus' differential but never used it) napa
power steering fluid (ATF) autozone
toyota red coolant (this stuff is pricey) local toyota dealer :(
2jzgte water pump (oem) $129.30 toyotapartscheap.com
2jzgte rear main seal (oem) $30.36 toyotapartscheap.com
lower radiator hose $11.02 toyotapartscheap.com
wastegate $120 shipped from driftmotion.com
Oil filter relocation kit $60 ish summitracing.com
oil thermostat 40$ summitracing.com
k&n oil filter $9
2jzgte timing belt (gates) $75 titanmotorsports.com
charcoal canister $40 supraforums.com
oil pan gasket material Loctite brand $9 for a big ass tube summitracing.com
o2 sensor bung for new downpipe $24 bicperformance.com
oil cooler 61$ summitracing
intake pipe 15$ ebay
air filter k&n 54$ summitracing
MKIV supra throttle cable $65 driftmotion.com
2jzgte serpentine belt (power enterprise) $90 Titanmotorsports.com (ships out to me this monday)
some iridium spark plugs 45$ NGK from a local parts store
wiring harness $800 yikes thats pricey! but its OEM quality :) they dont have those for 2jz aristo engines in mkiii LOL. Dr. Tweak @ pheonixtuning.com he'll hook you up.
oil pressure sender from a 7mgte=$free
water pump pulley = Bought the aluminm set from driftmotion.com 60$ same size as OEM
Intercooler hard pipes 160$ from driftmotion for everything i'll ever need hah.
2jzgte high pressure power steering hose from an mkiv supra. This was 55$ from a parts store... beats over 300 from toyota!
banjo for brake booster on 2jzgte intake manifold with fitting about 20$ for everything from toyotapartscheap.com
r154 inspection covers and gaskets 120$ for both new from toyotapartscheap.com
Turbo!!! i bought one! Turbonetics 62-1 dual ball bearing from treadstoneperformance.com
downpipe for turbo didnt buy it but i know i am going to buy a 90 deg bend of stainless steel to weld to a vband and on the 90 deg going to weld on my o2 areas so i can at least drive it without a CE light sometime and fogure out the o2 wiring. going to get this from treadstone as well welding done locally
Intercooler!!! i got a different one (the 1JZ one from Driftmotion)
HKS 40mm wastegate 403$ from mvpmotorsports.com
AEM uego 205$ mvpmotorsports.com
2jzgte mech fan clutch and blade - 258$ toyotapartscheap.com
Turbo Heat Blankie 150$ titanmotorsports
Oil lines for my turbo 115$
FPR suprasport 150$
fuel management - MAP ECU 2 baby
oil lines for t4 turbo - Treadstone 115$
Clutch suprasport.com $538.83
fpr bracket 15$ suprasport.com
Lipp upgraded ground kit 27$ suprasport.com
15$ for an extra ground cable for lipp
oil pressure sensor + plug pieces supramania.com 20$
FPR kit driftmotion 204$
vac lines + fittings 61$ suprasport
Stage 2
Coil Allen bolts(twins turbo) 15$
Second blow off valve - Synchronic Purchased 200$something
Injectors.
fuel pump install
Hook up and tune on my Map Ecu 2.
Sandwich adaptor for oil relocation
EGT gauge
install my clutch
BIC poly mounts
driveshaft 350$
the other two things empera makes i need to get up on since mine are thrashed
my crankcase hoses between valve covers
new alternator (mine was tested fine, problem solved)
larger a/r turbine housing - Purchased 235$
Syris;990321 said:
More people need to understand this....4rth gear is direct drive on a 5spd and is 1:1 and will give true results which is where is should be dynoed, now on a 4spd automatic it should be dynoed in 3rd which is technically direct drive as in auto's 4rth is overdrive.
tlo86
Jul 24, 2005
3,914
Colorado
The anticipation was STAGGERING
Engine, the last time it'll be in my car.
Engine Sold, picking up the r154 in 2 days (and the coiter pin in need with it lol, and a stock slave cyl for now..), BIC mounts = purchased, t4 single turbo manifold = purchased, still need a few other things of course :) working on pulling out the engine today... might also purchase a high pressure power steering line from autozone or similar store~ may also order my oil filter relocation kit today as well...
tlo86
Jul 24, 2005
3,914
Colorado
no pictures (yet getting some WED when i pick up my tranny) i have my 7m out :):) thrilled about that. just need to get the harness off... i took it out with the downpipe and tranny still attached man its hard when you do it by yourself.... but i have it done (friend came by and helped hehe), transmission is not off the engine and about half way done with taking the harness off.
what was really surprising is when i took my engine out the mounts fell off... wow i thought they were bad and i had no idea usually you hear knocking or something but nope i didnt...
*edit*
Ordered!
1jz oil pressure gauge sender adaptor (hey maybe it will work :):))
1JZ-GTE Flywheel(over 500$ from the dealer :()
1JZ Bellhousing(also over 500$ from the dealer FOR EMPLOYEES i hate the parts guy at my local toyota dealership, prick)
2jz throttle cable (i know i couldve used a corolla but honestly i do not have the time to just goto a junk yard :( WITH THE TIME I PUT INTO THE 2JZGTE SWAP!! lol it would be silly if i didnt have at least some time to work on that ;);))
ARP 1JZ Flywheel Bolts (Might as well, still not sure if they are reusable but who cares i shouldnt need to take off this flywheel unless i buy a lightened one, and replacing my rear main seal before i install tranny)
ordered these from driftmotion.com NOT the dealer hehe saved me a few bucks.
*edit* Harness is out! r154 is almost to the garage.... just a note when removing the harness from the 7mgte, take off the throttle body and isc makes things a million times easier... and i only forgot about two plugs hidden near alternator... (oops! oh well i only need the body pins :), now i just need to be very careful when taking the jz harness off )
tlo86
Jul 24, 2005
3,914
Colorado
after talking to dr tweak (he is doing my wiring) i should have full use of ALL of my gauges! (minus the boost gauge but thats my own doing hehe)
manifold came in the mail, looks good just have to grind some~
thermostat and gasket came in mail as well as a gasket for the oil pickup in the oil pan.
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
God damn it joe. I cant tell you how many times I tried to squish that damn bug.
Tlo86 - That project = o.o I will for one be tunned in.
tlo86
Jul 24, 2005
3,914
Colorado
OneJoeZee said:
You're going single right? Stock twins are so last year!:)
yeah thats why its taking so long lol :) i still need to get pics :( i still only have pics of the day the engien first arrived!
the manifold that came in (ebay) still needs the inside grinded a bit from the welds ~ they did most but its one of the best ebay manifolds i have seen in person. err minus the fact the holes for the studs dont quite line up :( (only one is off)
tlo86
Jul 24, 2005
3,914
Colorado
he just had to pose...
new one :)
not sure what to do with this cooler... or where to put it =/ was my tranny cooler now? my p/s cooler? :p
Clutch hardlines and ss line :( i have no idea how to route the long line hehe
Which battery to use? (Note: NWS i just noticed Lol)
car garaged every day = rust? the donar replacements outside every day on a parts car = not rusted? lame lol
now what am i going to do with these? =/
do i NEED 3 starters?
2jzgte auto trans, ebay manifold (that doesnt fit), twins.
I <3 supras
88' turbo harness and 89' turbo harness for those that get confused about wiring...
Still not ready to throw it in!
the r154 :) shifter boot from misc vender Empera, knob was free... it looks neat i think... and my third transmission ! :S
tlo86
Jul 24, 2005
3,914
Colorado
OneJoeZee said:
Progress is GOOD. Keep it up!
thanks! ordering new stuff every day so im just waiting for that *need* list to be just a few things~
*fit the repacement fender on today, the paint doesnt match, the fender doesnt sit perfectly, and its all scratched up not but i dont care i will repaint it british racing green *soon* anyway... hehe
tlo86
Jul 24, 2005
3,914
Colorado
noone told me taking the 2jz harness off was this easy :) the clutch i bought is also in the picture and im trying to hide it under my car with no success. not very proud of it lol
noone told me taking the 7m harness off was this hard! :(
these pictures are off the new iphone. the camera on that thing isnt that bad! if i didnt break phones all of the time i would get one! :)
*edit* stuff came in the mail today:sarcasm: pics tomorow:) mounts on the way as well.
tlo86
Jul 24, 2005
3,914
Colorado
this came in the mail!
whats inside
r154 bellhousing for 7m r154 bellhousing for jz
thought i would compare the starter area for the engines, the thicker one is the 2jzgte the thinner one is the 7mgte. you can notice on the bellhousing the area for the starter is larger on the 7m... and smaller for the jz of coruse it is obvious why this is :) just remembered a question if the 2jz starter will work with the 1jz bellhousing or something similar~ well therres the answer hehe
made a little workroom
more transmission stuff~(for sale Lol!)
where i keep my hood, old downpipe, fan+clutch and fan shroud
dancing pile of ecu's
not a good pic. im prolly going to go back to the tundra deck since it can fit way better than the scion
stuff i bought for the 7m ive never used...
THIS IS THE PAN YOU NEED FOR YOUR 2JZ :):)
and the finale for today.
tlo86
Jul 24, 2005
3,914
Colorado
hey look some more mail :)
Thank you marlin crawler! was it worth 18$ shipped? i do not know! here it is compared to stock which really wasnt that bad anyway. just dirty... i figured it would be a polyurethene bushing but it was a 'hard urethene'
here it is installed. i never shifted an r154... maybe i shouldve installed this after :)
here is my relocation kit and oil thermostat! the brass fittings are not tight but man i know why people pay the extra for other fittings... the brass threads are rough... all permacool minus what spins on the block thats earls. notice the size of the oil filter...
its huge! o_O i dont think i purchased the right one but it works so... whatever :)
thechori
supra-deprived
Oct 3, 2006
567
houston
how much for the old DP? me want!
actually, i might need that shroud too! :0~
nice build though, looking forward to seeing it finished
marlin crawler bushing is made of very hard urithane (sp?) not rubber like the stock part...
did you get the little cup as well?
