Nick M;1811886 said:Another that knows just enough to get himself into trouble. The air is moving not static, and the turbocharger has a heat shield.
I noticed heat issues when I had the stock intake manifold with metal hardpipes. This was driving around in traffic though, not racing.
Nick M;1811886 said:And how much stuff did you take off the car that Toyota put there but didn't really need?
A bunch of stuff. I run a standalone, and there are no emissions regs here. I've also changed ignition setups, fueling, etc, but kept things like the PCV system, etc. I've modified the car for my goals, just like every member here does.
Nick M;1811886 said:You would have a leg to stand on if you knew what you were talking about. There is one benefit, the shorter intercooler pipes. And that was done because the JZ is a gutless wonder down low. If the plenum is bigger and the runners bigger in diameter and shorter in length, then you would have a case. But that isn't the case. You are making the case for front facing, not an improved manifold. By the way, the fastest drag car in the US uses the stock manifold. Ported I would guess.
I'm not arguing that the stock intake manifold is garbage, I'm stating I think that overall, the engine can be improved on. I would assume that when switching to FFIM you would optimize the design to suit your goals, ie plenum volume, runner diameter/length, throttle body size, etc. Who is the fastest drag car in the US right now? I looked at the 1/4 mile time sticky, but I don't know if that's up to date.
Nick M;1811886 said:Hey I got an idea. Take the man hours you spent changing over, then see if my taking 30 minutes to change plugs every 2 years is the same.
I thought my statement about that would obviously a joke, apparently not, my bad
