The 7mgte Bolt-On Turbo Catalog
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
3p141592654, very nice.
I saw an identical one that was used selling on ebay around a year ago. Guy was only asking $500 and no one bid. I couldn’t believe it. I was seriously thinking about picking it up, but it’d be a downgrade as far as power output from my current 62-1 turbo. It would be nice to have ball bearings tho.
suprapilot
109
Los Angeles Area
Sounds like SP is the only one you can order threw for the Precision turbo CT-26. It's hurts! I could have order one and I remember the guy on the phone saying bring me $1000 cash and I build it any way you want lol!
suprapilot
109
Los Angeles Area
Another very nice option would be a new cast log manifold with a T4 flange and do an EFR on it. Or a new cast housing for an EFR that bolts on would be sweet as well.
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Suprasport sold the Jr for $1525 in 2010 when I bought this one. Install kit was another $200, and so was the elbow. I don't know how successful the Jr series was for Suprasport. I know a couple of people on here who have them, but I think the Sr line was more popular.
Piratetip
Far From Maddening Crowds
1,179
69
MKE, WI
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
suprapilot
109
Los Angeles Area
Yeah that or a CT26 to T4 adapter using the stock manifold.
Though then you would be limited to only internally gated turbos.
Is this the only style T4 cast manifold on the market now?
Yes I believe that is a copy of the HKS and everyone sold these. Makes me wounder if they all bought them from the same supplier in China? I would run internally gated my self and close the WG flag. Now the bad part is you can't run the stock heat shields like you can on the Turbonetics stock looking log unit.
suprapilot
109
Los Angeles Area
Yeah, but heat-shields are pretty minor.
You can easily find some rigid bendable heat shielding now and make your own custom ones.
Very similar to OE style shielding.
https://www.heatshieldproducts.com/automotive/heat-shield-and-thermal-barriers/inferno-shield
For me it was about keeping the OEM look on one of my cars while making 500+whp. I don't know why but the idea of a stockish looking engine bay on a low mile car I have that makes decent power is exciting lol. I have the Turbonetics Turbo which I was planing to redo with all new upgraded parts since the CT turbos are not be made any more? Mambatech does make the larger AR housing and larger CT turbos. So maybe the last guys are them now?
Piratetip
1,179
69
MKE, WI
Eh I don't know if I would trust Mambatech.
Has anyone here taken the gamble and bought one of their turbos?
Funkycheeze
Grease Monkey
Jul 3, 2009
163
Calgary
I am pulling the 7M from my car to upgrade to a 2J and will be selling my ITS based stage 4 GTS 60-1 triple ceramic ball bearing BOSS turbo with all the lines etc. It has just over 60,000 km on it but was rebuilt less than 5000 km ago (new seals). Will make 450 wheel easily at 16 psi. PM me.
tissimo
Stock is boring :(
Melbourne, FL
I've got two, not sure their origin. One is machined out toyota housings 60-1 and a P trim turbine I think (aftermarket center section), the other is an aftermarket exhaust housing and PT6176. Heres pictures of them with a stocker to compare.
I'm planning to use the 60-1 on my new 7m build and hope for 500whp, if i cant reach it, i'll swap to the 61.
Piratetip
1,179
69
MKE, WI
Looked at the Mamba offerings a bit more.
Not sure the exhaust housings size they chose to make are a great choice.
Looks like most of the stuff they offer has a 7 cm turbing housing.
Which seems awfully small for an engine this size.
Wouldn't all these turbos severely limit the top end power?
http://shop.mambatek.com/product.sc?productId=2177&categoryId=-1
http://shop.mambatek.com/product.sc?productId=2178&categoryId=-1
https://www.ebay.com/itm/For-TOYOTA...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
tissimo
Stock is boring :(
Melbourne, FL
Yes, the stock manifold and exhaust housings are small and restrictive. If you're looking for top end power/lots of power a t4 setup is far superior, plus has tons more options. The bolton is for stock appearance, simplicity, and quick response.
Piratetip
1,179
69
MKE, WI
So the stock CT-26 turbine housing is also 7cm / .49 A/R that Mamba lists for their custom made one?
I am trying to figure out why they chose such a small custom made housing that can adapt to Garrett CHRA's.
suprapilot
109
Los Angeles Area
Mamba also has a 8cm .64 AR housing as well. I believe the larger housings are the same that came on the Turbo A cars.
suprapilot
109
Los Angeles Area
The CT with the larger turbine has the smaller AR housing that that will limit it. The center is the Chinese CX racing style t61 turbo looks like?
Piratetip
1,179
69
MKE, WI
Yeah I saw a select few of their turbos paired with the 8cm.
Don't see it being sold separately though.
Might contact them and see how many options they have available.
Ah I found a sold one...
https://www.ebay.com/itm/MAMBA-TOYO...tULU8Q9lziPACfrxwuSDk%3D&orig_cvip=true&rt=nc
Edit:
Found it. PN: 013-1152
http://www.shop.mambatek.com/search...3D3BDA7C041.p3plqscsfapp006?keywords=013-1152
