Tein or Megan?
SublimeSupra
Dreams of the Touge
Jan 17, 2006
170
Largo,Fl
I currently have the megan streets on my 2002 WRX and they ride great and the quality is very good.I track my car monthly and havent had any problems with them.My brother in law knows almost every import aftermarket performance company out there.And he told me to get them in the first place because there made in the same factory as cusco coilovers and that there very good quality.They have a pretty aggressive spring rate and dampening rate for a street coilover.The only reason why there priced so cheap is because they are a new company.In a few years they will be expensive like everyone else.Thats what i have to say about them.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
Thanks for all of your guys input. I think I will go with the Megan's. If they break or are not what I like I will return and/or sell them and try the Tein SS. Thanks again for your thoughts on my sitiuation.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
i DD on my megan track's and they have done nothing but work great for me so far. only complaint is that i cant get the rear as low as i want, but as low as i want is lower than 95% of most mk3 owners would want their cars to sit anyways...
GeneStarWindGSW
Been To The Other Side...
Mar 25, 2007
992
No Man's Land
www.bidmingle.com
2 inches off the ground :biglaugh: ?
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
basically! :biglaugh: i want the rear fender lip right above the rear tire with basically zero gap and about the same up front. i can post pics of how low the rear goes if anyone wants them.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
I think the megans are second best option to the Tien RAs
The Tien RAs are about the same stiffness and identical to the megans except the Tien RAs are better for handling and dailey driving the Tien RAs have helper springs on them so you dont bottom your car out on dirt roads even when really low and you dont feel the small bumps as bad.
Also you can rebuild the Tien RAs i have the superstreet artical from 3-4yrs back that tells you how to rebuild them adjust them even more and do it all yourself.
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
i have never bottomed out my megens even when driving them through lame road construction in North west calgary. calgary seems to excell in cterrible civil engenerring.
from what i have driven on, megans are a good buy for the cash you put into em.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
turbogate
Life is Boost
May 18, 2005
425
South, FL
I received my Megan coilovers, and they look to be very high quality. Time will tell. Mr. Leany Shifter, what size rims do you have?
