After I installed my wideband I am running lean under boost. 13 lbs, with 550s and lexus, stock FPR and stock pump. My timing was too advanced, by alot. Now I want to set it at 10 deg. Once i get it set at 10 i remove the jumper t1 and e1 my timing does not jump up to 12 as described as tsrm? I think my TPS is off, I cant get that fucker within TSRM specs up for the life of me. After fixing my charcoal canister sitiuation, I run lean at idle (15.0:1 AFR) with timing set at 10, but no difference in t1 and e1? Does this mean im not going into closed loop? The only code i get is 51. And usually thats TPS, however it also could be due to my removed AC completly.
~scott
			~scott
