Supra Turbo fan clutch questions
JDMMA70
2,550
Houston
I recently picked up a used Turbo Fan Clutch to rebuild. My question is I've heard that Turbo fan clutches are supposed to be bigger is size compared to N/A fan clutches. However from the pile of fan clutches I had to choose from I compared the turbo fan clutch I got to a N/A clutch and noted no differences what so ever. Other than the 10 blade vs 7 blade and the colour on the mounting portion being different (blue for non turbo and orange for turbo) I noted no size difference or any difference at all as a matter of fact. What I did find though was a few other turbo supra owners I was with at TX2K10 who had purchased new Toyota fan clutches. Those clutches they bought were bigger in size and had more fins on it than the turbo fan clutch I had. Did Toyota redesign the fan clutch for the turbo supra? Mind you I went through a pile of about 5-6 fan clutches and I found N/A and turbo other than the colour they weren't different.
JDMMA70
2,550
Houston
I know IJ those who bought them new recently are much bigger in size. However im guessing the original gte clutches aren't as big.
JDMMA70
2,550
Houston
I got pics of my Fan Clutch i got off the 7MGTE you can see it has the orange part.
For the second measurement its 160mm across
JDMMA70
2,550
Houston
My Autozone replacement thats on my car right now is smaller than this clutch in the pictures. I was looking at every Supra Turbo at TX2K10 and they all had the same clutch posted in the pics. Except for the ones that bought a brand new clutch from Toyota. Like i said those were noticibly different. I am curious though if Toyota did redesign the clutch or listed a bigger clutch under its P/N?
Jeff Lange
Administrator
4,926
17
Sunnyvale, CA
jefflange.ca
Like was said there were 2 different GE clutches, and 3 different GTE clutches.
16210-42030 - Early 87 7M-GTE (Obsolete)
16210-42050 - Late 87-88 7M-GTE (Obsolete - 1 still in Toronto warehouse)
16210-42070 - 89-92 7M-GTE (Still Available)
16210-42040 - Pre-89 7M-GE (Still Available)
16210-42060 - 89+ 7M-GE (Still Available)
As for which ones are which and which ones are what size and what the differences are, I cannot answer these questions. At this point however, you really cannot be sure a clutch you pull off of a car is the original clutch that came on the car, and with 2 of the 3 types of 7M-GTE clutch obsolete, getting a hold of some new ones to compare is not likely to happen either.
Jeff
JDMMA70
2,550
Houston
Jeff
So i take it the 89-92 Fan Clutches are the better cooling fan clutches of the bunch vs. the 87-88 7MGTE fan clutches? Now that i have the one that i have i wonder if its worthwhile to even rebuild it or to just bite the bullet and get a brand new fan clutch.
