Supra mk3 electric cooling fan
cmdeoro
VRROOOMMM!!!!!!.....PSSH!
Jan 21, 2009
103
Miami
SideWinderGX;1245146 said:
Noone knows. The general answer people respond with is 'more than electric fans', which is never backed up with any substantial data.
Well then thats the biggest problem. Does it really have more cfms? I mean thats what it all comes down to at the end.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
Yeah, its done in weird setups like MR-2s where they dont have much air flow at all. With an FR car like ours with plenty of room for a big ol front mount, I dont think it'll do much; unless you are in stop and go traffic, in which case you wont need it anyways.
SideWinderGX
733
Syracuse, New York, United States
If I had to put money on it, I'd say the mechanical, with a properly working clutch and fan shroud pulls more air in the upper rpm band. But that's just a guess.
Just did some googling, because now I'm really interested...found this:
http://howto.globalvicinity.com/gv_wiki.php?wi=191&co=1&vi=1
Now it's specifically for RX-7's, but there's some really great info in there on how much the stock mechanical fan pulls (calculated out), how important the fan shroud really is, etc.
Supracentral
12
jetjock;1245587 said:
Not true. More is not better. In fact it can be detrimental...
Many people have learned this the hard way not running a thermostat on the road course. Sometimes the water doesn't stay in the rad long enough to cool down.
SideWinderGX
733
You're smarter than me....just some clarification: it would really cycle through the radiator too fast to cool down? I never ever would've thought about that...
Yes, Moroso even sell a kit of restrictors to run if you remove the T-Stat so you can "tune" the operating temps.
SideWinderGX
733
No shit, I never would've thought. I'll read up on those restrictors too and how they work.
speedfreak426;1245612 said:
I wish I had enough room to install the factory fan setup.....
I had no choice but to put in e-fans :( now I constantly worry that they will fail.
pics
You could always splice into the power wire going to the fans and run it to an led mounted somewhere on the dashboard. It wouldn't help if the fan motors blew, but that's the least likely scenario anyways.
jetjock
creepy-ass cracka
9,439
I had no choice but to put in e-fans :( now I constantly worry that they will fail.[/IMG]
Wire them right and the odds are they won't. That said there are lots of simple ways to sooth your nerves. For example you can monitor fan current or speed or use a temp alarm. I use the stock fan and still have an alarm. Very easy to do using the stock AC overtemp switch...
Dr Chill
4 hungry Supras
Nov 27, 2007
329
Mississippi
I have an electric fan on 1 of my N/As , But Im gonna keep my clutch fan on my GTE as it moves hella air with a good shroud ..
speedfreak426
380
Brighton, MI
I just have them hooked up with a thermostatic controller.... sooo none of the stuff you mentioned.
Any suggestions, or well, more in-depth suggestions?
jetjock
creepy-ass cracka
9,439
First, it'd be better to monitor the fans rather than temperature because temp actually needs to climb before you'll get an alarm.
Using the stock AC over temp switch (Water Switch # 2 iirc) is simple. You tap the line where it comes in through the firewall and connect to one terminal of the alarm device you want to use. A Mallory Sonalert or similar piezoelectric sounder works well. Connect the other terminal to a source of switched power, e.g. power when the key is on. Ty wrap the sounder up under the dash or throw it in the glove box and you're done. You will now get an alarm whenever coolant temp exceeds 235 F, a value too low to cause any damage and one that shouldn't occur unless there is a problem...
jetjock
creepy-ass cracka
9,439
No problem. Someday when you hit it big get one of these:
http://tinyurl.com/c4mevy
Aviation engine analyzer. Monitors and graphically displays everything from oil pressure to individual cylinder EGTs. Programmable alarms, data logging, voice prompts, you name it. I actually know someone who has this in a car. Way overkill but pretty cool nonetheless. Not cheap though...
mattsplat72
is sofa king
Jan 17, 2006
1,738
In the case of the 77 celica could you run a fan with out the fan clutch. I guess I really dont get the purpose of the fan clutch I don't remember older V8's with them could you run with out the clutch assembly and if so would it work? Wait... Would it work in a safe and stable manner?
