I usually don't ask too many questions, but don't want to waste time chasing the problem, so I figured I'd ask and see if anything else made sense.
Here's the details.
Just finishing up putting together another Supra, 89. Put my old motor in it (from my 90). Nothing changed as far as timing belt/timing. Only thing not done is the exhaust (open 2.5" dp) - waiting for a cat.
It's not throwing any codes. Was throwing air signal, but a different afm, and we're good to go.
It'll start, idle surges up to appr 12-1300 rpms. Will sit there for a minute and eventually die. If I touch the gas in any manner, it'll stumble and die almost immediately. Changing the CPS timing doesn't change much.
Mainly, I'm thinking IC piping leak since it seems to die out with anymore fuel.
Any other ideas before I start tearing around on the IC piping?
Thanks
Kevin
Here's the details.
Thanks
Kevin
