Stock idle rpm?
SublimeSupra
Dreams of the Touge
Jan 17, 2006
170
Largo,Fl
As the title states.I was jsut wondering what does a 7mgte normal idle at?Mine is at about 1100 rpm and wont drop even after running for a good 30 mins.Does it have a idle adjustment screw or is it more complex to change it?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Mine settles to about 750-800 once warm with lights and AC/ heat off. It could be several different thing from timing to sensors. The trouble shoot in the TSRM may be helpful.
SP 7M
Use your GUY instinct
Apr 6, 2005
274
Oceanside (for now), CA
The normal idle is listed in your owner's manual. You can easily adjust the idle. Your next order of business is to get a TSRM if you don't already have one.
Joel-Those last two sentences were not questions. You may want to address that before the GP come get ya. ;)
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
I see your point. I was sort of phrasing them as a question because I am not 100% sure it would be helpful. lol...
I fixed it for you. :)
Jimi87T
1,127
4
Colorado Springs
The throttle plate should be totally closed and the ICS should be keeping your idle in check. Make sure the throttle plate is closing all the way, if it is you could have a vacuum leak.
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
Thanks Craig. The way I see it, I treat everyone with respect until they prove to me they are not worthy of it :) Then it's just a matter of self control and some experience on forums like this, I learned not to take crap too seriously.. :)
Also I delete bunches of my own posts before MOST people can see them... LMAO...
This is what i was refering too (no high idle drop) page FI-18
http://groundsky.co.nz/techinfo/TSRM/07_FI.pdf
I see all ;)!
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
So are you that quick on the refresh button Ian? Or can you see my deleted posts? Because that last post was only up for 10 seconds and you feed it back to me.. LOL
:dunno:
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
GrimJack said:
Mods or Admins can still see deleted posts. Proves useful now and then, usually when flame wars start and people start trying to cover their tracks.
ruh row, don't tell them that!
SP 7M
Apr 6, 2005
274
jetjock said:
Really. I'd be interested in hearing how this is accomplished. There is no procedure for doing it in the manual (nor should there be). Can you explain?
That's funny. I don't recall saying that the procedure to adjusting your idle was in the basic owner's manual.
Either quote me correctly or not at all. I don't appreciate being taken out of context, please and thank you.
There's your explanation.
staticpat
Supra Chair!
Birmingham, AL
I don't know why everyone says adjusting the idle can't be done, or isn't worth it. There's a bleed screw on the throttle body under a rubber cap. You can just back it out a little for a higher idle. I've done it with no repercussions.
jetjock
creepy-ass cracka
9,439
That's funny. I don't recall saying that you said the procedure to adjusting the idle was in the basic owner's manual. Or in any manaual for that matter.
My explanation isn't for "adjusting" the idle. Nor are the odds likely it would apply to his car (or his problem) anyway.
