Stock CPS limits
mytmk3
643
christchurch
my car is currently being tuned 7mgte my tuner is running into issues with poor signals from the CPS he suggested he can have a look and tightning it up/ try someone else's but being used to working with RB's he wants to put a trigger wheel on the crank and go that route as they always have probelms with them and figures having issues now at only 10psi when we start to push 3 times that jst going to run into issues again.
Money is tight but am seriously considerng this rather than wasting money trying a whole pile of 2nd hand cps's and I wasting money changing? is the CPS perfectly fine? numbers I can only assume will be over 600hp atw on E85
If the bearings are ok you can close the airgap down to 2 thou that will give it the best output possible, also remove any unused coils if you're using a standalone as they do interfere at high rpm.
mytmk3
643
christchurch
Searching found a thread with paradox having issues with his on his haltec said they speced his down to 2mm/8thou from 4mm/16thou so you recon go to 2 thou?
I will see If I can get them to try this tomorrow before I commit to spending more If I dont need too. also when you say remove coils? im still running stock coil packs (shamefully admit dont know what you mean)
Also if the cambelt wasnt tensioned enough would that give jumpy signal?
There are 3 coils inside the CPS most times when you run a standalone you only utilise 2 of them, the 3rd unsed coil is still generating a voltage and this can confuse the issue so you remove it, If the cam tensioner sping is new that's as tight as it needs to be.
2mm is 80 thou not 8
te72
Classifieds Moderator
6,626
10
WHYoming
IJ.;1908180 said:
What can I say, no kids to pass this stuff along to so you guys are it by default ;)
I'm still waiting for you to get back to me on those adoption papers daddy... :rofl:
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
He is still buried in paperwork from the restraining order he has on Andy but I am sure he will get around to it :p :rofl:
Sent from my DROID RAZR using Tapatalk 2
mecevans
1,295
M-bay, cali
This is what the signal should look like..
