My name is Steve, and this is the build-up of my 1991 Toyota Supra Turbo.
In October of 08, I traded my 93 auto Corolla with 205k for a 91 5-speed Supra turbo with 195k. I had $1200 into the corolla and he gave me $300 cash, so I got a Turbo Supra for $900. The problem was the Supra didn't run, and the PO thought that the head gasket (that he replaced) had blown. I quickly found that the CPS had pushed out of the head due to there being no bolt holding it in. Started up and drove fine, but it leaked oil like mad, smoked badly on decel, had missing bolts, vacuum leaks, crap all over the place, and had very little power overall, and last but not least, it DID have a BHG. It needed a lot of work.
In light of this, I considered my options: JDM 7M swap, 1JZ swap, build/rebuild the current motor. After much research and saving, I have begun the process of building my Supra's 7MGTE engine.
Here's what my build looks like right now:
Longblock:
Original 200,000mile block.
Original Crankshaft, high-speed balanced.
JE pistons .020" over ceramic coated crowns, dry lube coated skirts, heat conductive undersides.
Eagle rods
ARP head studs
HKS Stopper 2mm Head gasket
NDC bearings
Machined block for MHG 20rA
Fully ported head, machined to 20rA
+1mm Ferrea Stainless valves
Supertech Dual valvesprings/Ti retainers
Bronze Manganese Valve guides
3-angle valve job
Gates racing Timing belt
Brian Crower 272 camshafts
5M Oil pump pulley w/ custom spacer
Fidanza adjustable cam gears with locknut modification
MK4 Motor mounts
New oil pump, water pump, oil pump drive shaft bearings, freeze plugs, gaskets, seals, etc.
Induction:
Custom (Truax Racing) long-runner FFIM with a Q45 throttle body
Comp Turbo Billet 67mm, TBB, P-trim
Turbosmart Hypergate 45mm V-band Wastegate
Ceramic coated .81A/R T-4 turbine housing w/ 3" V-band outlet
ETS 5" MK4 intercooler (tight fit)
3" custom welded piping
Custom modded SSQV
Electronics:
AEM EMS
5-bar MAP sensor
Sequential injection rewire
1ZZ-FE Ignition coils on Albert's bracket
AEM UEGO Wideband
AEM Tru-boost with 5-bar external sensor
Auto-meter sport comp 2 Tachometer w/ shift light
LIPP Alternator relocation bracket
Cooling:
Koyo Radiator
Full-flow oil cooling system
Canton oil filter head, -8 lines, oil t-stat, B+M oil cooler
Stock oil cooler refitted as a better power steering cooler
Fuel:
E-85 fuel
FIC 1350 injectors
Dual Aeromotive 340 pumps
Dual stock fuel lines and dual stock filters, -6 lines to rail
IJ's Aeromotive A1000 -6AN AFPR
Drivetrain:
Spec P-trim twin plate clutch w/ aluminum flywheel
Built R-154 with lots of goodies
Modified stock shifter (not sogi, lol)
Dahn Automotive 3.5" AL driveshaft
3.91 LSD differential, soon to have 3.73 spool'd weir diff as well.
Exhaust:
Raptor Racing tubular exhaust manifold and V-band downpipe
Custom 3" exhaust, compliments of Emilio Rescigno
Exterior:
Carbon Creations CF hood with Aerocatch hood pins (many thanks to Dan Getzke)
Shine Auto G-spec CF front bumper (being painted)
Brakes:
ARZ Willwood 13" 4-piston fronts
Goodrich Stainless flexible lines
Stock rears with EBC Redstuff pads/Brembo rotors
Suspension:
Eibach Lowering springs
Tokico Illumina II shocks (Tems still works)
Energy suspension bushings all throughout front and rear
Wheels:
17x9 5Zigen FN01R-C w/ 235-45-17 Goodyear F1 GSD3 (10mm spacer needed to clear brakes)
17x10 5Zigen FN01R-C w. 275-40-17 BFGoodrich G-force Sports
15x8 Summit Pulsars with 26x11.5x15 Hoosier Quick Time Pro's
-List updated 4-21-14-
My goal is to have a car that is streetable and responsive. I'm also over-building the engine so I have space to grow in the future. (which has happened since this thread was originally made)
This will be my first high-performance build so I'm trying to do it right and keep it reliable.
And here's what you all want to see- another mk3 supra. Whoo hoo!
Yeah, it smokes. :cry:
The engine as I got it
Interior mess
Pulling the motor
All my new goodies
Updated as of April 28th 2011
Longblock:
Eagle rods
ARP head studs
NDC bearings
3-angle valve job
MK4 Motor mounts
Induction:
Custom modded SSQV
Electronics:
AEM EMS
5-bar MAP sensor
AEM UEGO Wideband
Cooling:
Koyo Radiator
Fuel:
E-85 fuel
FIC 1350 injectors
Drivetrain:
Exhaust:
Exterior:
Brakes:
Suspension:
Wheels:
Interior mess
Pulling the motor
All my new goodies
