SS autojunk manifold users, I have a question
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
But finally got the dip-stick in.... just took some convincing.
supra8795
193
Illinois
Im using a hard line for the return i will get some pics when it is done.
Yes the compressor hit the runner so i made a half inch stainless spacer.
Havent done the dipstick yet but i think i have a good idea on how to do it.
87_7MGTE
SOLD :(
Bellingham, WA
IJ: is there any difference in running the turbo oil return straight into the pan like you have as opposed to where it drains stock?
I just did mine that way as the GrpA pan is already plumbed for it!
I've used the block return a few times as well.
williamb82
909
4
Tampa, Fl.
havent made the oil drain yet.
yes the compressor of my gt40 would hit the runners, so i bought 2 1/2in thick flanges to use as spacers and it clears now, and my car is an mkii with front sump so my dipstick is in the fwd most hole on the block so clears fine. hope the info is useful. didnt get my mani from ssautchrome but its the same one.
figgie
Twin Cities, Minnesot-ah
I would think this would be better as there is no way for the crank to grab the returning oil unlike the block return ;)
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
i got braided lines & fittings to make my oil drain
didn't change the dipstick at all.. just made a little metal bracket and bolted it with one of the compressor housing bolts
and .6 housing doesn't touch exh manifold
and if it does... talk to IJ and see if you can convince him enough to make an adaptor, or he'll at least give you a suggestion on where to go hehe ;)
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
MDCmotorsports said:
Im thinking of making a t4 to t4 flange with a piece of square tubine between them, and twisting the top flange so that the turbo is pointed towards the right front headlight.
thats an excellent idea.
It is a bitch to make anything larger than 3" DP fit with the way the turbo sits now. Will also help the guys that still have power steering fit there intake piping.
My drain is the same as MK3Brents
and Yes my comp. housing hit the runners, I made a spacer for it. 1-1/4" I think.
