Ok what the heck.. I have some pics now..
To start off here I decided to do a few things on the extra side so to speak to make things a lil different.
After starting off with a new block and build a new bottom end with new piston's, rods and such I decided to do a lil more. I want to thank my good buddy Ron R for again helping me with this build and others that will come along in helping soon enough. Nate, and Tom to name a few
Other parts added are Titan cam gears, (hey came polished but I sent them out to have a clear anodize on them to give a satin finish.) turbo blanket, New clutch set-up, 4" V band (thanks Sean at Titan motorsports)
The head is pretty much maxed out for porting and I have added some custom Billet steel cams from TED to help make the engine breath some more.
After months of work and time on waiting for parts, I decided to paint the bay but a lil better this time. I brought it to a guy that Ron knows that does resto's for a living and he does a GREAT job . (you will pay for it) I had the bay stripped down to the bare metal and then had most holes filled in the bay. 147 to be exact. They were all welded and then ground down. By holes I mean > the stock intercooler holes, (pass fender) the windshield bottle res hole, the fuse box hole for the wiring that is and the battery tray has been shaved out to name a few bigger ones I had done. From there, it was etched and then primed painted etc.. Sounds easy but I can say this ... IT IS A VERY TIME CONSUMING JOB! and time is money. Thanks to Champion Toyota, I also have decided to add many new parts from Toyota like the 3 vents in the back of firewall, wiper arms, visor for winshield, the hood latch, many interior parts, seals and brake lines since I took out my old ABS (has been unhooked for 4 years and did nothing and I have a BIG brake kit from AP anyway) Also added are new bolts for bay in SS to give a nice clean touch. The engine is also surrounded with certain bolts. See if you can see them
I also have gone bigger with my intercooler (tank to tank) 31x14x4 AKA frame rail to frame rail as it barely fits between LOL.
I have also made many new custom one off billet 6061 parts for brackets, pulley's and such.
I will add more as time goes by since Ron started this thread. I will keep it to show a few what's up with the build.
Duane
Custom one off pulley made from Billet 6061 with counter bore holes and the "seven m" engraved in to it.
Custom Billet steel cams from TED components. Set in head to measure shims etc..
New latch from Toyota and last one in North America! Custom bracket for oil cooler seen in pic along with all SS allen bolts throughout bay.
Custom intercooler from Extreme Turbo Systems (Thanks Joe)
I decided to hide the ballist for my HID's under the bumper so it is clean. Custom mounting and wiring will be hidden as well.
See! No battery tray nor wiring harness or any holes for the fuse box harness
Ron and I have moved the wiring and will extend it to another location. (Unsure where at this time.)
