*SM Access problem in Australia*
CTsupra
^ this is why i'm studying engineering science with emphasis on computer engineering. very interested in computers, but do not understand what all of that crap means yet...
hope the problem gets resolved soon IJ. make sure you wear the tin foil and plastic wrap helmet! skynet is coming for us!
SupraMario
I think it was the google
7
The Farm
well that ends my search. Ive been digging around on the school network for stuff to by pass whatever was blocking you all i have found is Lan stuff though, good for work i guess.
thevork
ShoarmaTeam Member
Hi,
I'm experiencing the same problems in The Netherlands.
At my work I can access the forums, but at home I cannot.
Strangest thing is, the server refuses my connection from my provider (@home) but not my provider at work, wich is a university.
Dns servers are all thesame everywhere. cache cleared several times and nothing works.
When I setup a VPN connection at home to my university it works again (otherwise i couldn't post this message).
I also cannot reach bard.net or the forums by ip-adress so i'm pretty sure it's a routing problem, not a dns issue.
I included both my failing and working routing lookups. Note that the last few servers are thesame, but nonetheless it's not working.
That's why i'm thinking the server is blocking several big subnets.
the failing one:
2 13 ms 8 ms 8 ms 10.239.64.1
3 9 ms 13 ms 8 ms r1-ge0-2-201.almel1.ov.home.nl [213.51.134.225]
4 18 ms 11 ms 8 ms bb1-ge8-1-0.zwoll1.ov.home.nl [213.51.157.14]
5 12 ms 12 ms 17 ms bb1-ge0-1-0-0.amsix-nikhef.home.nl [213.51.158.1
49]
6 15 ms 12 ms 34 ms bb2-new-ge2-0-0-0.amsix-telecity.home.nl [213.51
.158.121]
7 12 ms 14 ms 12 ms Essent.mpr1.if.ge-2-0-1.ams5.above.net [82.98.25
0.185]
8 28 ms 28 ms 28 ms so-5-0-0.cr2.lhr3.uk.above.net [64.125.27.177]
9 100 ms 103 ms 111 ms so-7-0-0.cr2.dca2.us.above.net [64.125.27.165]
10 99 ms 104 ms 106 ms so-6-0-0.mpr2.iad1.us.above.net [64.125.28.130]
11 100 ms 100 ms 99 ms so-3-0-0.mpr1.iad2.us.above.net [64.125.29.134]
12 100 ms 99 ms 99 ms so-3-0-0.mpr1.iad10.us.above.net [64.125.30.117]
13 101 ms 103 ms 104 ms ashburn-ibx.eli.net [206.223.115.46]
14 105 ms 103 ms 102 ms so-2-0-0--0.cr02.mcln.eli.net [207.173.115.109]
15 124 ms 113 ms 119 ms so-0-0-0--0.gw01.atln.eli.net [207.173.113.46]
16 135 ms 134 ms 139 ms so-0-0-0--0.cr01.dlls.eli.net [207.173.113.41]
17 134 ms 139 ms 135 ms so-7-0-0--0.cr02.dlls.eli.net [207.173.115.118]
18 170 ms 169 ms 169 ms so-0-0-0--0.cr02.phnx.eli.net [207.173.113.113]
19 171 ms 171 ms 175 ms p6-1.cr02.lsvl.eli.net [207.173.115.21]
20 171 ms 173 ms 184 ms ge2-2.gw01.lsvg.eli.net [207.173.114.94]
21 * * * Time-out bij opdracht.
22 * * * Time-out bij opdracht.
23 * * * Time-out bij opdracht.
24 ^C
Time-out bij opdracht is dutch for 'request timed out'
the working one:
1 22 ms 21 ms 19 ms utwente-vpn-mgmt.routing.utwente.nl [130.89.6.2]
2 26 ms 24 ms 40 ms if-vpn.routing.utwente.nl [130.89.6.1]
3 29 ms 40 ms 35 ms UTwente-CPE1.Customer.surf.net [145.145.4.5]
4 29 ms 30 ms 26 ms AT-500.XSR01.Amsterdam1A.surf.net [145.145.80.5]
5 27 ms 25 ms 28 ms Gi6-0-2.AR5.Amsterdam1.surf.net [145.145.166.21]
6 44 ms 27 ms 31 ms PO6-0.CR1.Amsterdam1.surf.net [145.145.162.1]
7 30 ms 34 ms 33 ms PO0-0.BR1.Amsterdam1.surf.net [145.145.166.34]
8 26 ms 26 ms 31 ms ge-3-2-0.nar1.AMS1.gblx.net [208.49.224.21]
9 113 ms 111 ms 129 ms so1-2-0-2488M.ar1.DCA3.gblx.net [67.17.67.53]
10 106 ms 115 ms 107 ms fe-1-2-0--0.er01.asbn.eli.net [207.173.144.25]
11 172 ms 107 ms 121 ms so-2-0-0--0.cr02.mcln.eli.net [207.173.115.109]
12 124 ms 131 ms 125 ms so-0-0-0--0.gw01.atln.eli.net [207.173.113.46]
13 137 ms 142 ms 136 ms so-0-0-0--0.cr01.dlls.eli.net [207.173.113.41]
14 142 ms 140 ms 142 ms so-7-0-0--0.cr02.dlls.eli.net [207.173.115.118]
15 183 ms 176 ms 176 ms so-0-0-0--0.cr02.phnx.eli.net [207.173.113.113]
16 184 ms 187 ms 184 ms p6-1.cr02.lsvl.eli.net [207.173.115.21]
17 183 ms 183 ms 187 ms ge2-2.gw01.lsvg.eli.net [207.173.114.94]
18 181 ms 183 ms 180 ms host.bard.net [208.186.130.196]
I'm not the only one in The Netherlands (Europe) experiencing this problem. A friend of mine who has an other provider and lives some 300miles away from here.
My ip at work starts with: 130.89.x.x (wich is working.)
My friends and my non working ip-adresses resp. start with: 212.120.x.x and 213.84.x.x
Thank you for looking into this. It's a very strange problem and prohibits us from visiting these forums.
