Routing PCV system into the exhaust
Justin
Speakers?
Spokane, Wa
What is there to know about this type of setup? I tried searching but it appears that when I search for 'Exhaust PCV' it pulls up every result with EITHER word, not BOTH words. Ugh.
As of right now I have nothing setup, at all. Before I get the car ready to run though I'd like to find a good solution...
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
If you connect the PCV system to the exhaust you generally use a "slash cut" piece of pipe welded into the exhaust at a certain angle. The combination of the slash cut and angle its welded in the pipe draws a vacuum through the pipe much like it does being connected to the intake. Only the crankcase vapors go into the exhaust instead of all in your intake pipe and turbo and intercooler pipes.
Its usually used for race cars and its not the most environmentally friendly way to run a pcv system.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
The Venturi effect is used to evacuate the crankcase fumes as opposed to re-routing them back through the intake system. It eliminates the potential re-circulation of oil if the catch can overflows and it reduces some inlets/outlets of the intake system. As far as downsides go, more hydrocarbon emissions and forget about running a catalytic converter. The ports have to be perfectly positioned in the exhaust system as well for the Venturi effect to take place.
Justin
Speakers?
Spokane, Wa
That would be nice, to have the vapors out through the exhaust. No cat here, so even if it was an issue its not any more...
There is not a single thing on my car that is environmentally friendly, matter of fact there's not a single piece of emissions equipment left on my car either :p
Hmmm... So its as simple as running a line from your valve covers to the exhaust port that is welded in at precisely the correct angle?
Seems like a pretty neat way to go.
To me, there's not a lot of an advantage to route the PVC this way. The vac produced per above is not very strong...it will work, but is way below the vac produced at the TB. Plus, you will need a one-way check valve in the line from the cam cover to the venturi at the exhaust to make damn sure you don't get ANY back flow.
Emissions wise...Adam is correct, higher HC and it WILL poison the CAT.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
Thats what I've been thinking as well. I know it could theoretically work, as I've used a vacuum attachment to shop air before, and shop air is 90+ psi. Venturis are our friend...without them, we wouldnt have carb'd engines to get us to EFI!
Its a shame we cant (shouldnt) dump it pre-turbo into the exhaust manifold though to burn it up. I sure as hell dont want any more carbon/oil on my turbine than necessary.
Supracentral
10
I've run this sort of setup on two cars.
#1 was on an Outlaw 10.5 car:
This car had a Keith Black Stage XV Hemi running on alchohol:
Due to the type of setup on this engine, there's really no manifold vaccuum to work with so you need alternatives.
#2 was on our NDRA Pro Street Tire car:
This car ran a modded 2JZ-GTE with a big Borg Warner Turbo:
We found that the "header vac" PCV system didn't work well with this setup. We had a 5" open downpipe and never really drew off vac the way we wanted it. In the end we settled for the setup as shown above. But this is a 7 second car. I wouldn't use anything like this on the street.
Stick with the stock type PCV setup, it's far superior and should only be removed if you have absolutely no alternative.
Even then I'd consider some sort of vacuum pump before I tried anything else.
Just my $.02, ymmv.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
Also airspeed has to be high enough inside the exhaust pipe in order to even create the venturi effect in the first place, thats why i thought it was only a race car thing where constant high velocity exhaust flow was actually achieved.
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
No slash-cutting for wesbeech :momaru:
annoyingrob;963914 said:
I've only ever seen one car with the PCV routed into the exhaust (A MKIV Supra at that).
Now you've seen two, and one's an MK3, at that. ;)
figgie
Twin Cities, Minnesot-ah
Wow Mike,
that is a nice car and engine :)
still own it?
The Supra, is that the AAP supra now? I saw it forsale?
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
there was a honda tech article on this subject and the vacuum pull by the exhaust versus vacuum by the throttle body were compared. iirc neither really pulled that much vacuum under boost the auther decided the exhaust one was suficent im still on the fence but i have ordered two slash cut pipes to use in my downpipe. if anyone is trying this you want the open side of the slash cut facing away from the flow and the pipe at a 90 degree angle to flow for maximum pull
