BlackDevilSupra;1627447 said:
The OEM version exhibits this problem also.
An old school engine builder mentioned to me to minimize the bypass just put a small film of high performance silicone sealant on the OD of the seal, and some lithium grease on the shaft prior to install. Haven't tried this yet, so I can't quantify it's effectiveness.
Great job on putting a basic demo of proper engine assembly
Grease helps protect the seal as you install it over the shaft it is to seal. Sliding a dry seal over a dry shaft end can damage the seal. I would not say everything I do is proper
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
but thanks for the compliment!
---------- Post added at 12:17 AM ---------- Previous post was at 12:06 AM ----------
buckets and Shims are all installed.
Little bit of high zinc cam assembly grease from my buddy Mr. Schnieder.
From here on I thought we got some pics of installing the cams and working on the shim clearance. But I don't seem to have them. So I missed out on pics of the cam install and cam gears.
Here is a pic of the rear seal on the motor.
Now a completed long block ready to head out the door.
So I am missing pics of installing the crank scraper, damper, and oil pan as well. Crap, maybe the next one.
