Here are some pics of when I revamped my rear subframe. The last pic is as it rests now, as I haven't begun reassembling the car. Bryan here (slow66) on the forum did all the welding:
here's another update, finally! i worked on the rear subframe today, got it completely stripped and ready for sandblasting. i also discovered (though, not difficult) a huge crack going right through the subframe over the differential. yes, it's ALL THE WAY through! yikes! pics tell all:
first, and most importantly, my helper!
the subframe removed from the car:
quick view of the center section, see anything interesting?
incase you didn't notice:
a bit closer:
the other side of the same crack- it goes all the way through the subframe!
axle removed:
and the other:
what happens when you twist the subframe with the weight of the diff still in there:
LSD removed:
LSD (it's a 4.3):
another pic of what happens when you stress that crack! yikes!
for some reason, i neglected to take a pic of the stripped subframe, so here's one from my cameraphone that i sent my friend to show him my progress- sorry for the crappy quality, i'll get a higher res. shot when i work on the 'bucket again!
stripped subframe:
keep in mind that i have nylon subframe spacers from BIC, and nylon upper/lower bushings for the control arms as well.
 i'll make sure to take pics of them, as well as post pics when i install them.
Bryan's house:
alright, here's a crap-ton of pics! all clickable thumbnails!
'blasted subframe in very light primer to prevent lots of rust:
Bryan starting his magic:
grinding of the wicked crack i had going on. (see previous pics for reference)
Bryan started to tig weld it. ran out of mig gas, which we later went and picked up from a buddy of his. thanks, friend!
Crack all welded up and ground down. ready for some plate steel now!
