Ram air duct into sealed cold air box
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Has anyone built a ram air duct that feeds into a into sealed cold air box that houses the air filter? Cold air being the 1st benefit, but then having increased flow and pressure helping the turbo at highway speeds. Would there be a noticable improvement?
With my new bumper I may have room to install a duct and get lots of air.
From memory I saw a 15c drop in Temps at the TB Blake, back then this allowed me to run 30psi/8300rpm on the dyno, before that I melted a motor at 26psi during a hard run.
Ma70.Ent
1,871
NJ
I've actually been getting ready to do this mod. Not sure if it'll help a lot but who knows....
SilverSupraT
7M '78 Toyota Pickup
Oct 3, 2005
556
Eastern WA
www.geocities.com
Thanks IJ, THAT is usable info, much appreciated! The pics are nice too :)
Brady
262
Bay Area
www.nbhq.net
i would love to see a dyno comparison between one of these "Cold air intakes" and your regular apexi filter bolted onto the end of a stock setup.
it was my understanding that the intercooler does more cooling of the air than any cold air intake could do. Besides, as soon as the "cold" air gets spun in the hotass turbo it gets heats up lickety split.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
IJ your idea seem to be the most logical, it keeps the filter from getting water logged and getting taken out from things that are kicked up on the road.
and if you have colder air to start out with, then it will heat up less as its compressed. which is why a cold air is good for turbo cars.
romaniello
94
Sanford, FL
Those might be good side benefits, except I believe his real reason is that down under he's not allowed to run an open filter.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
IJ.;1044080 said:
Yep the Can was a legallity thing the ducting was purely performance oriented ;)
(not a fan at all of front mounted ducts as I drive my car in the Winter)
So I take it the duct just sits in the void behind the wheel arch liner?
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
I would as well
It does most of it, but that was a really stupid comment...would you rather have winter air coming in or summer air? According to your theory, it wouldnt matter. However, cooler air coming in will get heated up roughly the same rate as hot air would; so the cooling air would still be cooler. Not to mention if its cooler outside, the intercooler will do a better job.
SupraMario
I think it was the google
7
The Farm
WTF? Winter?
