Pull engine with tranny?
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
In an earlier post I mentioned that I had pulled the engine and trans as a unit. I was suprised at how many people responded who just pull the engine. I have always pulled the engine and trans together wether an A/T or manual. I found that removing the 8 or so additional bolts and speedo cable saves a ton of heartache and time especially when you consider how hard it is to access the starter bolts, top engine bolts or aligning the clutch.
Just wondered how the rest of the world did it, maybe I might learn something useful.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I've done both. Certain cars, it's easier to leave the transmission in. It's ALWAYS easier of you don't have a load leveller, even if you have to move the transmission to get to the bolts.
With the load leveller, IMO, it'a s no-brainer. Pull both.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i usauly pull both.
although it also depends what i am doing at the time of the pull.
engine work, clutch,
when i was auto i pulled the engine by it's self 3 times, and the tranny out 2 with it.
ive swapped 5spd tran's and also done 2 clutchs..
i wont put up with the hassle of drianing fluids and pulling the ecu harness for a friend though.. if they need clutch work i'll drop they tranny out for them.
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
I don’t take my hood off I just pop off the shock ..... it has a release
Pull it together. Saves time and effort. I am a modern day "He-man" and that r154 is kinda heavy. It was a nice surprise laying on my chest :) and it was even more fun putting it up by myself …. Well not really I had to use a jack after a while.
buldozr
362
North Texas
bench pressing transmissions in suck, if you dont have the right tools and jacks, dont attempt. Too many times a buddy called me up out of the blue trying to swap a clutch and I wound up kicking the jack out and have to man handle the trans, nothing sucks more when its not aligned right either and you have to restab it. If I dont buy a trans jack by the time I swap my clutch, Im paying someone with a lift!
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I usually pull both, but last time I just pulled the trans and swapped in my new trans.
Honestly, it was more difficult than pulling the engine/trans.
If I had a lift and didn't have to use jackstands, than maybe I would just pull one or the other and not both.
But on the ground, I'd definitely pull both.
