frank said:Not a good idea. You don't want to pull outside of the rubber insert on a balancer.
aljordan said:Is the outside ring going to seperate from the inside? If it does, I'd say you have a faulty pulley. Its a clearance fit anyway with the pulley. Should slide right off with no problems.
In fact, the last time I pulled a 7m apart, I pulled the crank pulley off with my hands. Slides right off with no great force.
