pretty positive its piston slap
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
the w58 has a push-type clutch, while the R154 has a pull, so it COULD have possibly been crank walk, but since you figured it out, then it's all good, just keep that in mind..
7Matt-GE
407
Becker, Minnesota
i have an A340E :\ so its definitely something else lmao
how could crank walk develop? i know its common with the DSMs but our cars?
Either style of clutch can get crank walk as there are 2 thrust bearings..
Rare but sometimes happens that an auto car will shag out the thrusts, usually for very different reasons to a manual.
More comoon is a cracked driveplate around the crank hub.
7Matt-GE
407
Becker, Minnesota
interesting, is there anyway i can prevent cracked plates from happening a second time? im probably going to keep this auto for a little while (a year or so till i can get money for a 5 speed) i know that flexplate isnt exactly made of titanium or anything ;)
Here's how I stopped it with my car, I replace the spacer disc with another driveplate minus the ring gear and use longer bolts.>>
7Matt-GE
407
Becker, Minnesota
hmm! ok, ok i see what you did there...where do you recommend i get longer bolts? hardware store? sorry if i seem to ask lots of questions i have never even heard of a flexplate till i got this car ;)
also whats that thing in the middle of the second picture's flexplate?
I used the ARP 4age flywheel bolts for the crank and a set of the weird ass m9 bolts I found at my bolt supplier that I trimmed to suit but if I were doing it again I'd retap the Torque converter to m10 so I could use easy to find generic grade 8 bolts.
7Matt-GE
407
Becker, Minnesota
oh nice! that doesn't seem too hard to do..ill try that out when i take this bugger apart! thanks man
7Matt-GE
407
Becker, Minnesota
IJ.;1575185 said:
I'll weigh it today and get a price on Shipping Matt.
If you can find a decent uncracked drive plate there it might be cheaper to ship just the spacer.
i do have a drive plate that i bought off someone else...did you weld those two plates together?
duffer26
74
Colorado Springs CO
hmmm sounds like i said something about this befor lol glad it was not RK it is not that big of a job just drop the trans like you are going to swap it out and replace
7Matt-GE
407
Becker, Minnesota
yes sir you were correct! hahaha im actually planning on pulling both the engine and the trans at the same time since i gotta do seal work anyways ;) it'll be loads easier to do with the tools i got. (having no lift sucks hahaha)
