Pre 89 foglight mod
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Hey Jeff, what's the highest current the fog relay can handle? I'd like brighter bulbs, but don't feel up to wiring in a relay up front just yet.
CRE
Oct 24, 2005
3,485
Denver, CO
HellsLegion said:
I think it said 100w when Iw as down there... Dot take my word. Im gonna go pick up a maybe 200watt relay at kragen when im pickin some stuff up this week
Ah, thanks! I forgot to look. But will the old stock wiring handle that much juice? I think you may be better off adding a relay up front. Just trigger it from the fogs' original + lead and route the power from the battery with nice, new and higher guage wire.
I was thinkin' of seeing if anyone local carries something like an 85W lamp I could use. So the stock fixtures use H3s?
T
turbo06
Guest
thats exacly what I did so now with that relay I put on mine I'm gunna by those super yellow fog light bulbs like those new Mercedes have.
CRE
Oct 24, 2005
3,485
Denver, CO
Hey, has anyone pulled out the little metal diffuser which sits infront of the bulbs in the foglight housing?
One of mine broke loose and I've been wondering if just pulling both out will improve the lighting.... or just hose the light distribution?
8,900
jdmk3_87t said:
HellsLegion if you have or ever get the time...can you do a write-up of your experience in wiring up the fogs? It would be a very big help for us pre89 guys. Just reading your posts gives me the motivation to try it for myself. The only thing I'm scared of is messing up the electrical system of my car. Help us please!
The year does not matter. On all cars you are changing the power source for the control side of the fog light relay from the headlight to the different 12V source. That is why you have to have the headlights on for the fog lights. The switch provides the ground path.
There is already a relay. But the question of amperage is a good one.
CRE
Oct 24, 2005
3,485
Denver, CO
I'm sure the relay could *probably* handle the power load, but I don't know that I care to trust such old wiring to handle it.... but then again the relay may be just as old as the car.
jdmk3_87t
Take it!
Apr 29, 2005
472
SoCaL
I tried doing this all day! For some reason it just didn't work...I was already getting nervous because I thought I would never see my foglights work again. I installed everything back to normal just like the way it was. Re-wiring fogs on pre89s are difficult compared to 89+. Never again.
CRE
Oct 24, 2005
3,485
Denver, CO
Really? I found it VERY easy.... once I realized I was looking at the wrong relay. :3d_frown:
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Rewiring it on Pre-89's is almost exactly the same as on 89+ cars, the only difference is where the switch is in the circuit.
I could rewire a pre-89 MK3 in about 15-25 minutes. Anyone that is considering rewiring anything needs to take a look at the wiring diagrams and understand what they are doing before they just start hooking up wires all over the place. At least that's my thought on the issue.
I will post wiring diagrams that show what needs to be done as well as pics, maybe tomorrow. I'll let you guys know. It's really NOT hard, and is probably one of the most simple things you can do on the car as far as electronics go. I fear for the rest of your modifications if you can't get this done properly. No offense, I'm just trying to look out for the Supras ;).
Also, those "caps" should NOT be used in your car, anywhere. Avoid them. You need to use quality crimps or soldering. Anyone that has done it with them I suggest you redo it. Please.
T
turbo06
Guest
I heat shrinked mine, looks very clean, I suggested you guys do the same because it makes it look stock if you get diffrent colors.
bonus12
Backroads Driver
Jul 15, 2006
143
CA
Jeff Lange said:
For Pre-89:
1. Find the fog light relay, cut the white/green wire (pin 3) and ground it.
2. Find the fog light switch, cut the red/black wire (pin 4) and connect it to a switched +12VDC power source. See Note
[/i]
in step one, which end of of the white/green wire do u ground? the side going to the relay, or the side going into the dash?
thanks in advance
CRE
Oct 24, 2005
3,485
Denver, CO
thanks in advance
Ground the relay side.
bonus12
Backroads Driver
Jul 15, 2006
143
CA
ok, thanks. i thought i had everything set up right when i had the dash side grounded, but the headlights and the fogs wouldn't go on at the saem time. however, the brights and the fogs did go on simultaneously. also, the fogs worked by themselves.
i'll try grounding the relay side.
for everybody else: http://gallery.sanitylapse.com/v/supra/displayimage.php?album=66&pos=0
unfortunately, this didnt help me very much.
CRE
Oct 24, 2005
3,485
Denver, CO
I'd be careful with the dash side grounded. If it's connected to the same white/green that comes from the dimmer you risk burning out the dimmer. Depends on how the dimmer's made, apparently there are two different internal circuits for the pre89 dimmer.
bonus12
Backroads Driver
Jul 15, 2006
143
CA
cre: grounding the relay side didnt work for me. when i tried it, it was working like stock. i have checked eveything else, so i am a little confused as to why this isnt working for me. i'll try again tomorrow when i am fresh.
CRE
Oct 24, 2005
3,485
Denver, CO
HellsLegion said:
Im going to do this on Jenny's 89 today.
http://www.supras.com/06/techcenter/display.php?QID=42
Following these instructions. Ill tell yall if they are a good set or not!
FYI - those instructions are for 89+.
Exactly which wires do you have connected where?
