Ill give it a shot again. Im not too motivated to go at it again as when I went back there the first time. There was a ton of spliced wires. I think someone tried to do it before I owned the car. Ill give it a shot again!
Ok so all we have to do for the pre 89's is what you posted there and where set, can you confirm the wire colors because you posted that you wern't sure and I'm on my way outside to do it right now and i'll take my sidekicks so I can keep checking up.Jeff Lange said:All you are doing is isolating the fog circuit from the headlight circuit.
For Pre-89:
1. Find the fog light relay, cut the white/green wire (pin 3) and ground it.
2. Find the fog light switch, cut the red/black wire (pin 4) and connect it to a switched +12VDC power source. See Note
Note: For example: splice it into the black/red wire (Pin 2) on the cruise control switch (pre-89) or cruise control main relay (89+), or splice it into the red/yellow wire (Pin 2) on the fog light relay, however this will result in the fog lights functioning even if the car is off.
turbo06 said:Ok so all we have to do for the pre 89's is what you posted there and where set, can you confirm the wire colors because you posted that you wern't sure and I'm on my way outside to do it right now and i'll take my sidekicks so I can keep checking up.
HellsLegion said:I spliced all 3 wires together...
