Power steering sux when not moving 1jz swapped
siposupra
Sipo
Oct 12, 2007
23
denton
hey,
I am wondering why it is soo hard to turn my steering wheel when the car is not moving. I have to use both hands just to barely budge the wheels.
I have a 1991 supra with a 1j swap...i have never driven the car before the swap so i am not sure how hard the steering was before.
The progressive power steering is not wired up, but power steering IS hooked up and works great when i am moving over 5mph. I have driven other supras that have no power steering and their cars are alot easier to drive.
My question is, does anyone else experience this?? Is my steering rack messed up or my wheels too heavy?? I have no clue...
thx
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i'll put my money on that your power steering is not hooked up possibly. why isnt the pps wired up? might want to look into that. for now is there any noise coming from the pump? fluid level? wheels wont affect power steering at all
also check and make sure there is a cooler hooked up to the p/s system...
tlo86
Jul 24, 2005
3,914
Colorado
Nick M;1011539 said:
Make sure the pressure and return lines are not mixed up on the rack. Don't forget to see if you installed a belt.
is it possible to mix them up? from what i remember there is a hose barb(like) fitting and a high pressure bolt in. for the 1jz there is only 1 belt for it :biglaugh: i hope he installed it!
siposupra
Sipo
Oct 12, 2007
23
denton
the lines are correct...theres a belt too. I drove the car without p/s for a while, and after p/s i can only notice its easier after about 5mph.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
Because its more expensive to replace and I dont feel that it does all that much really. I've had an 89 as well. The age of our cars + the likeliness of someone using the wrong fluid means that its also likely that the steering rack will need to be replaced.
siposupra
Sipo
Oct 12, 2007
23
denton
IJ.;1013159 said:
LOL @ this thread!!
Who would have thought not wiring the steering would result in heavy steering..... :nono:
PPS just assist a little bit in the steering...i should at least be able to steer one handed without PPS hooked up
siposupra
Sipo
Oct 12, 2007
23
denton
we have another supra with no PPS hooked up, it works fine...come to the conclusion that i have a weak power steering pump
